#2531
Kyle's coming up with a design to convert the ski locker!
![]() Actually, I wonder how many on here use that ski locker and for what? I would like to clean it up nicely and plug it up to use for something, just don't know what i'd put in there.
You can drank em purty but ya caint drank em skinny... |
#2533
Snow day for the kids today so stayed up last night and worked on the floor panel that sits just behind the dog house...
I wanted to be able to remove the dog house when necessary to clean the bilge or work on the motor or whatever. I did not like the fact that the dog house only opened so far with the gas shocks and if I removed them, I would have to basically stand the dog house up vertically which then it had to be secured so it did not fall. The PO had installed a piece of pretty heavy diamond plat under the floor panel as a backing for the hinges. I wanted to be able to just unscrew the hinges and remove the motor box without having to mess with the screws that were there with the nylon nuts...what a pita as I had to remove the dog house and panel at the same time or try to reach underneath to access the screws. ![]() So here is what I came up with...still need to clean everything but at least you get the idea...hinges seem secured very well.
#2534
I hate those nylon nuts when used in the wrong application...the ones on the hinges for the dog house were pretty bad but I will just use them until I can get new ones...hinges are scratched a bit but $30 a piece, no way...I will just clean them and re-install.
John, you didn't need to go through all that work. Pop the two shocks off and roll the engine hatch straight back with the panel still attached and it lands perfectly upside down on the sun pad. I did it on my '96 and do the same thing on my '07. Its a one man operation. However, I think my '96 had 2 or 4 screws in the floor to the stringers. 'O7 has nothing.
#2538
Brushed more snow off the boat.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#2539
![]() I would still have to pull out the 4 screws that hold the panel to the stringers then...I guess that is really the only difference. Come on Cameron, 6 inches of snow here today...had to do something! ![]()
