#2191
Great idea!
My kids are no longer afraid to look behind the furnace in the basement.In the boat, in the cold garage is perfect. ![]()
Jeff |
#2192
Put a drop light in it. Still not ready to winterize yet. Getting close though.
99 MariStar 230 Sport LTR 330 |
#2193
Polished a few more sections of my oxidated rubrail...
#2194
I had my daughter's new bow hidden in the boat.
#2195
Adjusted the brakes on our tandem trailer yesterday. Manual said for two sets of brakes, tighten until the wheel doesn't spin, then back off 5 clicks. I went with 6 back off clicks and there is a very slight rubbing sound as I turn the wheels from the shoes rubbing on the drums. This is the first time I have adjusted our brakes. Does this sound right? I just don't want to have trouble in the spring. Thanks.
1998 MariStar 200 VRS, LT1, PowerSlot |
#2197
The manual is a guideline since one persons idea of "tighten until the wheel doesn't spin" may be different from the next (one person may be stronger). If you start off tighter, 5 clicks may not be enough. Sounds like you got it right.
Jeff |
#2198
Thanks JDC. The drag is extremely light, and only at one or so points in a rotation. I was just worried about going too tight. Sounds like I did OK. Thanks again.
#2199
+1 sounds right as well...too loose and they can lock up rolling forward.
The light drag is really enough to have the shoes touch the outer (hopefully round) drum. Like barely touch it. Just enough to make a rubbing noise. If you are too tight going and retrieving your empty trailer will be interesting as the wheels would lock up real fast when driving around without the weight of the boat on the trailer. Wheel hop and lockup would be extremely easy on a light trailer. Everyone here described how it should be done correctly. I just wanted to give a result incase you happened to have them too tight because you are so strong ![]() I can't even believe that 5 clicks back from locked up would even be correct. That would burn those shoes up real fast and you would get lock up and possibly not be able to back up or extreme wheel hop when empty. Sounds like you are good though. Cheers
Rollin' Gangsta Style Quote:
