  #201
Old 01-27-2011, 02:32 PM
LaRue's Avatar
LaRue LaRue is online now
Boat: 2000 Mastercraft Maristar 210 LTR
Not sure what you sort of guidance you are seeking. depends if you are replacing a portion or all and would depend if you are looking to replace just the insert of channel.
My advice would be to contact dealer, get what you need (see if color is still available) and then it is a matter of removing old and attaching the new. Make sure to use epoxy in the mounting holes. the warmer the material the better.
Old 01-27-2011, 02:39 PM
jamica joe's Avatar
jamica joe jamica joe is offline
Boat: Mastercraft, 205V, 2000
Just not sure how to get started... There are so many good step by step threads for almost everything that you can / could do, but I have nor seen one that describes this replacement.
Joe
Old 01-28-2011, 12:08 AM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Joe
I would pull the insert out of the rail all of the way around the boat. There is a cap on the back of the boat were the rail starts and finishes.
Then drill out the rivets and remove the rail from the boat.
Your new rail will come in 15 ft sticks. My be 10 foot but I think they are 15 foot.
Use a heat gun to bend the rail. I measured my rails and cut the sticks so that they would be uniform and even. With the wasted part of the stick I heated it and bended it to see how to work the plastic. How hot was too hot and if it would change color. After heating and bending along with re riveting the new rail, re install the insert.
I filled up a bath tub or a big bucket and put the roll of insert in hot water for a while. It is like unrolling cable. You want it to get warm so you can work with it. Start putting the insert into the rail. A heat gun is required for this as well.
If you dont have a heat gun go get one from Home Depot or hardware store. They are not too costly.
Project should take a Saturday afternoon. On mine, I drilled some extra holes through the top cap and the bottom hull and riveted the rail and the hulls together more than what the factory did to make mine a little more strudy.
Rollin' Gangsta Style
Old 01-28-2011, 10:51 AM
SunCoast 83's Avatar
SunCoast 83 SunCoast 83 is offline
Boat: 2009 Tournament Team 197
Bought a new bilge pump. Never installed one.....any pointers?
Thanks
2009 MasterCraft 197 TT
#46 of #100
Old 01-28-2011, 07:09 PM
03geetee's Avatar
03geetee 03geetee is offline
Boat: 1983 Skier 190 Stars and Stripes
Thanks
I didnt replace my pump, but removed everything for an interior revamp so pretty much the same. Go ahead and remove the following....(you dont have to but I like to clean things up while Im in there and have as much room as possible)
-Observers chair/bench upper
-Observers lower fiberglass frame
-ski pylon
-open your doghouse
-remove the battery cables/battery
Other then that its simply removing the first fiberglass panel in front of the doghouse (screws) and exposing a nice area to work in. While your in there replace the hose and clamps too. Test it all before you reinstall it and your good!
heres a pic of the mess I started with....
Anything else just ask!
JTR
1983 MasterCraft Stars and Stripes
Cream/Red Metal Flake
"Powerslot"
"The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish."
-Charles Chaplin-
Old 01-28-2011, 08:16 PM
-ski pylon
-open your doghouse
JTR
What, no after picture???
Old 01-28-2011, 08:19 PM
03geetee's Avatar
She goes for interior this monday! Carpet, new vinyl, then I will send all the chrome trim to get replated. I cannot wait, which means you will have to as well!
JTR
"Powerslot"
-Charles Chaplin-
Old 01-28-2011, 11:38 PM
JTR
I'm sure you wont forget about us when the boat comes back all pretty.
Old 01-29-2011, 08:15 AM
davidstan's Avatar
davidstan davidstan is offline
Boat: 2008 X2
major detail and change bilge hose for blower. Fun! Selling her next week and looking for newer MC.
David
2008 X2 MCX
1999 Maristar 210 (sold)
1996 Bayliner 2050
Old 01-29-2011, 11:26 AM
tex's Avatar
tex tex is offline
Threw my new jacket onto the backseat!
