  #2071
Old 11-25-2012, 11:20 PM
MCOCD@13 out of 10
Originally Posted by TOO-TALL View Post
Winterized the MC today......
Found the big yellow banner I made you...I'll get it to you next season......
Old 11-26-2012, 10:38 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
I used mine this weekend...
Old 11-26-2012, 10:53 AM
SP Maristar's Avatar
Degreased the motor with Simple Green and vacuumed every crevice I could find while brushing with a paint brush to loosen what I figure is the PO dog's hair. Not much there, but I am running out of things on the puttering list, so I am getting down in the weeds. Still need to finish the trailer maintenance - grease wheel bearings, inspect/adjust brakes...
Old 11-26-2012, 11:19 AM
MCOCD@13 out of 10
that's not work!!!! lol...
Old 11-26-2012, 04:53 PM
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
Had an old Infinity BassLink from a car that I previously sold, so went ahead and installed it for kicks while the turkey cooked on Thursday. Took the boat out for a ride on Friday--weather was just okay but it was great to be out in the fresh air and water. After living in Minnesota for nine brutal winters, it was a blast to be boating in late November!
Sunday spent replacing some odds and ends hardware (stripped screws, etc.), interior cleaning, and testing some scratch removal protocol (wet sanding in some inconspicuous areas to learn just how this is done correctly). Just ordered an Optima Bluetop and a Borg Warner isolator relay so that'll be the next thing to add so I can enjoy the stereo without worry.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 11-26-2012, 04:57 PM
strad's Avatar
strad strad is offline
Used mine yesterday. Came back to the dock, dropped off the vehicle driver, restarted it and it was suddenly idling about 200 rpms low and sounded like the trans was lightly knocking in gear. Immediately went to the tie off dock and shut it off. Later inspection found one spark plug lead loose. I hope that was the cause of everything! Won't know until next week. Trans fluid was full and in good condition. I haven't had the boat long enough to do a tuneup so I hadn't had a reason to check plugs and leads yet.
White with blue stripes.
Old 11-26-2012, 11:36 PM
carlsonwa's Avatar
carlsonwa carlsonwa is offline
Boat: 99' Sportstar
Continuation of my motor /bilge degreasing and painting, rusting parts under the motor box
Was going to have the harmonic balancer painted but turns out it is not recommend to super heat to the powder coat oven temps since there is this rubber ring.
So instead ill have to be content with just cleaning it up and use high temp engine enamel.
Old 11-26-2012, 11:52 PM
MCOCD@13 out of 10
I'm a big fan of "evaporust" it's non corrosive and it works. One downside is it takes more that you might think to clear all the rust. www.evaporust.com. I ran it thru the waterjacket to remove some of the rust...used 2.5 gallons...could of used 10...but its $22 a gallon if you buy it a gallon at a time...
Old 11-27-2012, 12:17 AM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Sweet......
---Animal house
Old 11-30-2012, 10:58 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
I changed the engine oil and tranny oil this past weekend then put it back in the garage. This is the first time I did the tranny oil myself as prior I had it done by the shop while doing a tune-up. I was amazed at the amount of stuff that was trapped by the filter (more like a screen). Cleaned out the transmission filter and reused.
Tonight I just got done with winterizing the ballast tanks. Also dry-blocked the engine. Blew out the heater and shower lines. Called it a night. Gotta leave other things to do so I have excuses to continue to go out in the garage to be with the boat, drink beer and lament about no more wakeboarding until spring.
