#1871
I replaced my fuel pump and filter yesterday. While I was in there I discovered a 7/16" layer of water in the bottom of the tank!
So I wired up some extention wires to hook the old pump to the battery, connected a long run of 5/16 fuel line and pumped the tank dry. A guess is I got 2 - 3 gallons of water out. I wiped the inside of the tank as far as I could reach with a rag. The new pump and filter will be starting as fresh as possible now. ![]()
Jeff |
#1872
New charger installed.
#1873
How difficult was your charger install? How long did it take?
#1874
Very clean install, Cameron.
What products, part numbers did you use?
Tim Gone, surfing. |
#1875
Install was not tough. I hate wires, so the hardest part was routing everything so it was hidden. I used a flexible rod to fish all the wires from my mounting location, under the floor and then to the battery box. All in all, it took probably 3 nights and a 12-pack!
![]() Quote:
I bought a Guest 16102. It is a dual bank 12amp (6amp per bank). I then installed a flush receptacle. |
#1876
Nice work Cam.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#1877
Rained most of the weekend so cut out and polished my gelcoat for a little more shine
#1878
WOW!!!!! Nice work!
#1879
That's absolutely beautiful! I'm going to be winterizing my boat here within the next two weeks. I'm going to work the gel-coat over good. If I'm lucky, it will shine out like yours.
Bill |
#1880
nice...sooo shiny....
