#1331
Finally
Finished the trailer death-march.... today after weeks of work
Didnt have the facilities/space to remove the boat so I did the following with the boat on the trailer (wished I could have blasted and powder-ed it but...): Wirebrushed the entire trailer, sanded, primed (brushed oil based primer), painted (brushed oil based enamel), new hubs, bearings, bearing buddies, grease, wheels, tires, lugs, lights, wiring (Soldered, shrink wrapped, sealed and covered with dialectric grease), lights, chains, spare wheels and tires (2), spare tire mounts (2), license plate mount, license plate, toung jack, and I am sure there is more but I forget... Pictures pending (still no camera - being borrowed) Also replaced the original fuel vent line from 1978 along with the hose clamps, and rebuilt/sealed the vent itself to the back of the boat..... washed off and waxed the bottom. Next up? Maybe electronic ign, coil, wires, plugs etc.... we will see. (Depends on time and money - with some other projects pending on the racecar as the season approaching quickly!) or if short on funding polish, wax, detail boat and then buff fenders.... Cj |
#1332
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#1333
IF YOU'RE NOT GRINNIN' THE MEAN ONES ARE WINNIN' |
#1334
way to be....thanks for takin' the care for an mc.
I cut some trailer bunk carpet in strips maybe 4 inches wide and 2 feet long.I put the strips between the straps and the gel coat.
"Hey baby want to make fourteen dollars the hard way?"--Rondhey Dangerfeild-Caddy Shack. "Was it over when the German's bombed pearl harbor ?" ---Animal house |
#1336
How do the boat buckles mount to the trailer?
#1337
One bolt in each unit.
Drill a 7/16" hole and put in bolt / nut. My MC trailer has pretty small angle steel construction, but it is well mounted. Tight fit for bolt on inside, had to dremel the bolt. The included bolts have a flare (like a built in washer - not sure of the nomenclature). I did not feel like running to HD for new bolts, so I modded the included hardware to work, basically flattening the flare that went on the 90' angle of the steel.
1991 ProStar / 351W with 1:1 Velvet Drive |
#1338
Rewired my amps with #4 wire, new fuse block holders, got my kicker km6500.2's mounted, cans polished, new nav lights in, new transom and front remotes wired/installed, stargazer installed, my dash/side panel back from dying, and my rear seat dropped off at the uphoslters. It was a MC tastic weekend!
#1339
#1340
Crappy old cell pics of trailer completion...
AND one pic to remind us that summer is on the way...
