#1001
Now the fun part.. Sanding and scraping / cleaning the manifold surface from the old gasket...
I tell ya', I was stumped as to my cooling issue and when I found the bad hose, I was very happy to have found the problem. Glad you took a look. I'd almost have to replace the hoses at this point since you have the risers off.... It's very easy from this point. .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
#1003
Skidim is the best place to do business when it comes to knowledge, patience, and support. Those guys are top notch.... .
#1004
@ mgorczak1:
The bad hose was the muffler to exhaust flange hose (3" x 3'). So to truly satisfy your OCD, your gonna have to pull floor panel behind the engine dog house and undo the 4 hose camps (each side and pull hoses). ![]() Think of it as an opportunity to clean the aft bilge, lube your rudder assembly, and inspect the aft portion of the blower hose. I found the battery terminal covers back there while I was working, slid them back up onto battery. Also rerouted the shower hose up against the hull instead of against the muffler. Sorry to be an enabler. But now you have me thinking that I should pull my starboard riser and put new bolts and gasket just to match the great looking hardware on the port side previously done in the past few months. Yours looks so clean and will look great once you reassemble with new hardware. Last edited by Lumbergh; 11-20-2011 at 12:02 AM. |
#1005
I started working on a new cable pull for the boat I have now, to relocate the battery to the front. I have the entire flooring out now as well as the seats and engine cover, fuel cell, etc... Cleaning the entire basement of the boat, pulling new cables, new stereo speakers / wiring, dual batteries, etc... It never ends... Hoses are next, and I am replacing the plastic riser connections with brass inserts too... .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 11-19-2011 at 07:35 PM. |
#1006
Thanks for enabling me I will probably change the hoses...since I have it apart... or maybe not...16 bucks for gaskets hoses still acceptable...rebuilt the trailer this year so I may have to wait till fall 2012.Good catch on the hose...thanks for the picture "cloaked" I am sure more people checked on their hoses...funny chasin some of the threads...removing the risers seemed difficult for many...cut a allen wrench made the job a snap!
Cut off allen and box end wrench made easy work of it. |
#1008
#1009
Oh one thing we should start talkin about is the damage the hands take when we work on the ladies...when the bolt broke loose and turned of course the ring finger knuckle quickly accelerated and found the nearest sharp point and proceeded to impale itself on engine...nothing major..."just flesh wound"!!!! plus some french....
I remind myself that a) I enjoy working on the MC and b) local shops charge $120/hr to do all the things I do / have done / will do.
Parts are, for the most part, the inexpensive part of the equation. |
