Old 08-24-2009, 08:19 PM
Tomahawk205
How to Patch Silent Master Exhaust?
I used some new screws to hold down my motor cover and they were slightly longer than the previous ones. Due to the longer screws, I put a hole in my exhaust. Now I have water coming in the hole. Note - I do realize this was a very stupid thing to do.
What can I use to patch the exhaust. It's a small hole, less than 1/4".
Thanks!!
Old 08-24-2009, 08:31 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Thanks!!
Try Mighty Putty, https://www.mightyputty.com/flare/ne...ID=80101233521
Charter Member Number 1
Quote: 2RLAKE,
Old 08-24-2009, 08:46 PM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
Originally Posted by TMCNo1 View Post
Or lay a little piece of fiberglass clothe over it and do a couple coats or resin with a throw away paint brush, let the resin dry between coats.
Old 08-24-2009, 09:24 PM
beatyr beatyr is offline
Boat: 1984 Stars and Stripes / 1999 SportStar
3M/1 qt. Bondo-Hair filler with long strand chopped fiberglass Part Number: 762 $13.99 at Autozone. You will need to sand a 1" diameter area around the hole with at least 80 grit paper (36 grit would be better). Wipe the area with thinner or alcohol for good adheasion. If your not concerned with finish then don’t worry about recessing from the original service as you can build up with an 1/8 “ material. Follow the mixing instructions and you will get a good structural seal. That’s a quick down and get’er done method.
Old 08-25-2009, 11:22 PM
Tomahawk205
Thanks for the advice. I'll probably try the Bondo route, sounds the easiest. I'll let you know how it pans out.
Old 08-25-2009, 11:27 PM
justinglow's Avatar
justinglow justinglow is offline
Boat: 1995 Prostar 205
I JB welded one of mine once. Small hole and lasted up until I sold it. Quick and easy fix.
1995 Mastercraft Prostar 205
Former 1986 Mastercraft Skier
Old 08-16-2013, 12:46 PM
misfitkidz2002 misfitkidz2002 is offline
Boat: 92 Maristar 210 351 Indmar
I imagine this thread is so old no one cares but I just used aluminum tape and have run my 92 maristar all summer; no leaks, no issues (so far and i figure ill keep running it like till the patch fails). Found the tape in the attic from the heat pump install in my attic last Jan. Cost was only about 5 minutes of my time.
