Old 08-20-2009, 10:41 AM
O2BESOHUGE's Avatar
O2BESOHUGE O2BESOHUGE is offline
Boat: 1991 MASTERCRAFT PRO STAR 190
Pylon Loose...in A 1991 Pro Star 190
I Use An Extended Pylon From Barefoot International...and Noticed That The Stock Pylon In The Boat Has Some "play" In It....is There A Way To Tighten It Back Down Good? Any Tips?
Thanks!
Jay
Old 08-20-2009, 10:46 AM
russlars's Avatar
russlars russlars is offline
My pylong was starting to creak and pop and just tightened it up a couple days ago. Not sure if yours is exactly like mine, but it was very easy. I has able to get to the bolts via the bilge. The ones that had worked loose on mine were the upper ones that attached the pylon to the metal bracing at the floor level. Now it is rock solid again.
Old 08-20-2009, 11:01 AM
O2BESOHUGE's Avatar
Thanks! Ill Check Those! Hopefully It Will Tighten It Back Down
Jay
Old 08-20-2009, 11:02 AM
flipper's Avatar
flipper flipper is offline
Boat: 1991 Prostar 190, fuel injected 302
Yes, open the engine cover and tighten the bolts
Lots of power is good, more is better, too much is just right.
'91 prostar 190
Old 08-20-2009, 11:26 AM
causewayskiier causewayskiier is offline
Boat: 1992 MC Prosport 205, 285 HP
On my '93 205 you could remove a small piece of floorboard just around the pylon. That will give you much better access to the bottom of the pylon.
Old 08-20-2009, 12:22 PM
wheeler's Avatar
wheeler wheeler is offline
Boat: 2007 X2
bump...wrong thread, sorry.
Old 08-21-2009, 10:12 PM
deereman's Avatar
deereman deereman is offline
Boat: 1987 Mastercraft Prostar 190 Powerslot 351 Ford
How about on an '87?
