faded hull
i have a 93 prostar with a green hull which has faded quite badly , just seen some posts recently which mentioned sanding or wet sanding the hull , what is involved in this process and is it effective ??
nil satis nisi optimum |
I restored the finish on my boat last winter. The stern had gotten heavily faded and the dark green was nearly white.
I simply used an circular polisher, some Moderate Gel-coat oxidation remover, a lighter polish, and some good fiberglass protectant, and it shone good as new. Took most of a day to do the whole boat. I'd give the oxidation remover a try before going at it with sandpaper. There are plenty of good threads on here; search for "oxidation", or perhaps "porter cable". /frank
1998 Maristar 200VRS |
We did the same with wet sand paper #3000 (with worn out ones which are used).After that hard paste with hand and soft paste with circular polisher.I will recommend to try first the hard paste on a smalll area if you get good result with that,you may not need #3000.
You should be very carefull not to work to long on one spot otherwise you may worn it out. Check the result. http://www.mastercraft.com/teamtalk/...ad.php?t=33716 Better to find a friend who is familier with these products otherwise I would do what FrankSchwab recommends and use commercial products.I think there is less risk of destroying the jel coat with those products. http://www.mastercraft.com/teamtalk/...ad.php?t=33716 Last edited by kiteklan; 01-07-2010 at 04:18 PM. |
Wet sanding is usually the last resort. My youngest bought an old SeaDoo that was yellow on bottom. The yellow was horribly faded. I was able to bring it back to life with "Finnesse it III" by 3M at 3500rpms with a sheepskin wheel. One advantage to buffing is that you can do limited buffing one or near stickers. Wet sanding you must mask off the stickers.
I say start with buffing. IF it does not give you the results you want, then try wet sanding. Just remember there is a natural order to things. From wet sanding at the highest grit to successively lower abrasive compounds until you finally get to a very fine polishing compound. Rotsa wuck.
1995 Prostar 190 Remember, we must share our waters and be respectful of other boaters. Rude people suck!
