  #741
Old 10-02-2009, 07:51 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
Originally Posted by MariStar-Man View Post
You're right Rob... You know, theres nothing like a reliable tool you can count on.
I won't put down HF, but I'm off to Sears tomorrow forthe right tool...
Thanks TMC, i actually did WD-40 and heated it up, but I don't hink I used enough heat. Will have a go again tomorrow. I still want to try the XMP Revolution as well
Remember, you not warming a chocolate chip muffin here, put some heat to it, rotate the prop and continue rotating it heating the hub between the blades. Be sure to leave the nut on, but loose, cause when it pops off it will do so with some force or it will bounch off and into the rudder, prop guard and maybe even your hand.
Charter Member Number 1
Quote: 2RLAKE,
Old 10-02-2009, 08:13 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
You probably need to heat the prop with a torch. That's what I had to do. Tighten the puller and then heat the hub of the prop with torch. Keep the prop nut on by a few threads because when it breaks free it is gonna fly most likely.
Old 10-02-2009, 09:05 AM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
And you would think that for $509 they would include a couple of Cotter Pins!
Should have went here and got a prop with removal kit for about what you paid for just the prop.....nut & cotter pin included http://www.ojprops.com/products/puller_kit
Old 10-02-2009, 09:10 AM
JohnE's Avatar
Boat: XT22
A simple site search might have proved useful.
Sears doesn't sell a prop puller. Buy one or see if you can find a boater who'll let you use theirs. You have a gear puller and they aren't made to remove everything.
Old 10-02-2009, 09:27 AM
ROB ROB is offline
Boat: MASTERCRAFT, MARISTAR 240, 1989, 454 INDMAR
You're so right. From an earlier thread regarding removing a prop, another member had asked to borrow a prop puller and the large gear puller from Sears came up in conversation. I know many on the site who have used it with much success, and, in a pinch, proves to be a very effective alternative.
Old 10-02-2009, 09:38 AM
coz's Avatar
coz coz is offline
I'm suprised Eric didn't jump in, I got this for $500 with the upgraded prop
Old 10-02-2009, 09:39 AM
ttu's Avatar
ttu ttu is offline
hey coz, you and i finally have something in common. i have the same case with puller and so forth.
Old 10-02-2009, 10:35 AM
JohnE's Avatar
Boat: XT22
Eric's too classy to tell him he overpaid...........we're not though.
Old 10-02-2009, 11:49 AM
coz's Avatar
coz coz is offline
You know?....I always wondered about those ACME props......why the ribs? all other manufacturers are smooth I don't know much about hydro dynamics but it seems to me a smooth prop would cut through the water better than one with ribs I would think with the ribs it would create resistance and more prop wash.
