#12
![]() ![]() I looked under the boat and I can NOT find the dern WAter Pickup! I only found the bilge hole to let out the greasy water that was left in there. Is the pickup maybe under one of the carpeted supports? ![]() Whers a good place for a boat cover? Well, I still have to change Engine oil and transmission oil, plugs cap and rotor, Impeller. Any other suggestions? Coming from a ZODIAC and a 20 hp Yamaha, I am a little overwhelmed with all the maintenance...I did come from Pleasanton MC dealer, and they said, "Buying boat was the cheap part...!" Last edited by MariStar-Man; 08-15-2009 at 10:57 AM. |
#13
You coudl have posted all of these in one thread? Im sure they will get merged. Nice looking boat
Quote: Originally Posted by Hoosier Bob She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
#14
www.skiboatcovers.com is the best
1996 Prostar 190, 350 TBI and Powerslot |
#15
Hi, Initially I put them all in 1 thread, and it told me that i was limited to 4 img's per thread... So i had to seperate them and an it took sum time...
#16
Most RV's have a 7 round terminal and need a 7-round to 5-flat adapter. Assuming your trailer has a solenoid to disengage the surge brakes when the vehicle is in reverse, you need to activate that somehow. That's the blue wire on the trailer side of the connector. Any 12 volt source applied to that blue wire (and the ground of course) will engage that solenoid. If your tow vehicle doesn't have a reverse signal to it's connector (which it won't if it is indeed a 4-round connector) then you could wire from your backup lights to that blue wire, which will then allow the trailer to back up when you put your vehicle into reverse, and you can avoid using the mechanical lockout
'04 MariStar 230VRS/MCX |
#17
4/5 images per post, and you can add as many posts in a thread containing 4/5 pic as you wish, rather than starting a new thread for each set of pics.
If a moderator happens by, there is a slight chance they will merge them for you.
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 08-15-2009 at 11:34 AM. |
#18
Consider it done
NEW SKINS ... Jim - "Upholstery Guy" (865) 995 0607 Hm (BSURE 2 LVMSGE) (865) 679 2246 Cph (ANYTM UPTO 9PM EST) friant9@aol.com I've got badass '93 MC BF 200 w/ a Yahamie ProV 200. M O S T A W E S O M E C R A F T E V E R B U I L T 'Luv'n life behind a Barefoot 200' atlfootr Last edited by atlfootr; 08-15-2009 at 12:12 PM. |
#19
Might I suggest that asap, straighten the trailer guide bars to a vertical position. Someone has been loading to boat too fast, bent them outward/forward and sooner than later they will probably allow you to get the prop into the trailer and you will get damage to the running gear and trailer.
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
#20
>>Quik Question<<
I am trying to start the engine in my driveway. the MC DEaler didn't Have Fake A Lake. Wherer can i tap into to hook up hose?
Anyone know if this yellow thingy has anything to do with hooking up water hose? ![]() ![]() Thre left vent are just hanging and not connected to anything. the last one on the righ looks like it goes into or to the lower right of enginne? ![]() |
