#1251
Thanks for the picture of the depth finder transducer!
I have a 2004 X-10 that had the transducer loose from the hull when I bought it. I have tried several locations with mixed success at depth reading while under way. If I can break mine loose again, I'll try locating according to your picture. |
#1252
![]() Yes, I'm still here thanks for asking...
Update: On the Maristar 210, 330hp Everything has been running great! I've had such good luck with her that I'm almost hoping something would break...lol This MC is built for the long haul. I'm very proud to own her...
1999 MasterCraft Maristar, V210, 330 Hp LTR Mods: Upgraded Stereo, Amp, 6 Disk Changer, Zero-Flex Tower, Custom Fit Bimini Top, and of course...Teak Oil! |
#1253
Hey...you are alive
#1254
![]() Working on the Teak Platform...
1. Cleaner 2. Brightener 3. Wetsand 150 grit 4. Now what should I do...? I could just add the TEAK OIL but someone said I should consider varnish. what Say you?
#1255
Depends on what your goal is. From a traditional perspective I've started doing a slightly different approach the past couple years.
1.) Go to car wash and use pressure washer with soap to quickly knock off all the crud. Once the really bad spots are clear systematically and carefully go over every inch until the entire platform is clean. 2.) Switch to rinse and use the same system to carefully and thoroughly rise the entire platform. 3.) Depending on how bad the platform was and how good you were able to clean it you'll either go to directly sanding or will do a light cleaner/brightener cycle. The first year I did this I was a bit nervous with the power washer (which you should be). The last three years I've gotten used to the process and can pretty much tell how close to get and when it's completely clean. I'll typically start sanding with 120 then hit it with 180 and stop there as I'm not looking for a show finish but rather one that will have some traction to it. My finish coat is always some kind of oil. The down side is that by mid summer I'm in need of a quick clean and oil on the platform as my boat sits on a lift exposed to the elements. That's like with teak. Varnish is a beast of another color. Depending the finish you're looking for and what looks good to you varnish may be a good choice for you. Most would probably disagree on this site. The problems with varnish that I see are..... Typically it's applied too thick and looks out of place, like it belongs on the SS Minnow. Most people use the high gloss which to me looks cheap and thus brings down the overall appearance of the boat. When I see it on a ski boat I typically get the impression the owner doesn't know how to take care of teak or that they're lazy. After a couple seasons it'll start to wear or chip and will really look crappy. Refinishing varnish will be much more difficult to do correctly as it will need to be stripped. As such most people that go this route end up with really crappy looking platforms and wish they'd bought fiberglass. So you can probably tell what camp I'm in. I like the look of teak on a ski boat and since I'm MCOCD really don't have a problem going through my new "green" and fairly easy process of keeping my teak looking good (not like a table top). If my boat were kept in the garage or even next to the house where I could keep the platform covered I'm sure this would be a once a season choir. Good luck either direction you choose to go! |
#1256
Glad to see you're still around! Is your prop still buffed out???
#1257
The prop is as green as the low-water lake I used to go to...lol
#1258
Well, I had to get in one post for 2015...
#1259
Find Kyle's thread on linseed oil and mineral spirits.
Tim "Heavy" beer is for wine drinkers that are too embarrassed to drink wine in front of their buddies. "Light" beer is a drinkin' man's beer! |
#1260
Thankyou for starting this thread MariStar-Man !!!. I have read all 126 pages and now have a grasp of what to lookout for and how to repair those issues. A "new to me" owner of a 1996 Maristar 225VRS. Especially appreciate the driveshaft alighnment /bent strut info as I looked at mine and have those issues. Let the restoration begin
Thread Tools | |
Display Modes | |
