  #91
Old 08-17-2009, 12:03 AM
MariStar-Man's Avatar
Boat: 1999 Maristar 210 VRS
Originally Posted by macattack View Post
Works great! Picked up the parts at my local ACE hardware store...
Nice hose!!! lol
Old 08-17-2009, 12:07 AM
don't put it in gear for any length of time, either.
i did put it in gear just to see if the transmission worked and got a metallic banging sound. i quickly turned it off. I will try it on a lake soon to see if it still makes the MC hammer sound...
Old 08-17-2009, 12:09 AM
Originally Posted by ROB View Post
How fast did you get her on plane in the driveway?
i'm a Newb what can i say... Damn tranny comes from Italy, and I don';t have any frequent flyer miles left...
Old 08-17-2009, 12:12 AM
Originally Posted by njskier View Post
If the engine sounds fine, drop it in the water and take it for a spin. Have a buddy follow you in another boat in needed, just in case you need a tow back.
Metallic knocking???? Better check the prop nut and make sure it's tight. The squeel is most likely the strut bushing being dry like No1 said.
I checked the nut, it tight. the sound was hopefully coming from the fact that there was no pressure on the prop like it would be in water. I'm almost ready to take her out. I need to wire up the Motorhome so the reverse signal goes to trailer.
Old 08-17-2009, 12:33 AM
Question While cleaning I noticed this Safety issue...Pics
The previous owner said I should always use the rope to tie the boat don, but the boat is not far forward enough? He also delivered the boat without any rear straps. I bought some today but what do i do know...lol
(I thought i would ask first before i drop the boat or something...)
Old 08-17-2009, 12:35 AM
Also found this with the nut hanging freely on the rod!
Old 08-17-2009, 12:36 AM
so I used my Dremmel and removed 2 threads... "Shhh I'm busy right now...lol"
Got it---->
All fixed and it looks like this:
Yes that nut on the bottom was used replacing the rod to the rudder...
Old 08-17-2009, 12:37 AM
You should put it on the trailer far enough to engage the Boat Buddy (the gray plastic covered part with the steel pin that's supposed to go through the bow eye and snap closed. Trailering straps are cheap but you should use them at the stern, too.
Old 08-17-2009, 12:41 AM
While at the MC dealer I picked up Safety Lockout
looks like this...
i still need to make a cable for it, instead of the wire tie
Yep, I'll be removing the Nickle and tape soon...
Also, I checked the master cylinder and topped it off with some dot 4. it was about a pint low! DOH!
Old 08-17-2009, 12:45 AM
Heres where they tapped in to get the hot and cold water
