Bying a new or remanufactured carb, plug and play or calibration needed?
I'm thinking of replacing the carb in my PS190 1989 since the one I have is automotive. If I buy a new one or remanufactured one that fit my 351, is it just to mount it and off I go or do I have to calibrate and tune it, not to keen on calibrating it.
All you may have to do is adjust the air/fuel idle mixture screws on each side of the front bowl and adjust the idle speed, other than that it plug-n-play. You can always try a fresh plug-n-play rebuild or have yours rebuilt for a cheaper price here, http://www.nationalcarburetors.com/m...relholley.aspx
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 08-12-2009 at 09:02 AM. |
Thanks! I found the nationalcarb ones at ebay, might go for one of those.
1989 ProStar 190, the floating Porsche! |
You will, as TMC has said, have to adjust the air/fuel mix and idle speed. Bring a small flat head screw driver with you on you first trip out. The only way to adjust is to have her on the water under load in gear. I ended up with my 4160, seating the air/fuel screws lightly and turning out 1 1/2 turns and then playing with it from there to find the right performance for my needs. Whatever you do to one side you do to the other.
Remember, you can set the idle speed at 600rpm in gear at idle to start with, but after setting the air/fuel mixture screws and getting the engine idling smooth in the process, you may still have to re-adjust the idle speed again, as the air/adjustments may alter the idle speed. Then after you have run it a while, check and adjust the idle speed again if need be.
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
#7
That's pretty much how it worked for me. After, all of the adjustments, and running at normal operating temp, I had to back-off the idle slightly. It's still a pretty simple project, and the performance gain is awesome.
#8
Ok, so you have to be idling in gear to adjust it? Can't adjust with gear disengaged?
#9
Float adjustments are pre set at the factory,Air mixture screws and Idle screw are all you need to adjust.Both easy and simple.in gear tied to the dock woks fine, If not adjust for 800 rpm you should loose 200 rpm in gear.
extreme tube tower |
