  #71
Old 03-29-2012, 11:51 AM
80starsmn's Avatar
80starsmn 80starsmn is offline
Boat: 96 Prostar LT-1
Port side general
Old 03-29-2012, 11:52 AM
80starsmn's Avatar
Port side brass elbow
Old 03-29-2012, 11:53 AM
80starsmn's Avatar
Starbord side
Old 03-29-2012, 11:59 AM
80starsmn's Avatar
Front general, all parts used (except needed two small hose clamps for connector line) are contained in the kit #180200 as per the service bulletin MC96-001 for $10.00 in stock at Midwest MasterCraft Crystal, Mn (763) 533-9666. Local hardware store had parts on hand but 3 times the cost.
Old 03-29-2012, 05:35 PM
pram's Avatar
pram pram is offline
Boat: 1995 Mastercraft Prostar 205
Send a message via MSN to pram
That is fantastic, talked to Corey and parts will be on there way tomorrow for mine to do the same
I live in my own little world. But it's OK - They know me here
MONKEY FACE
Old 03-29-2012, 10:12 PM
mattb mattb is offline
Boat: 1995 MasterCraft Pro Star 190 LT-1/Powerslot
I need to do this as well. Thanks for posting!
1995 MasterCraft Pro Star 190 ~ LT-1 ~ Power Slot
Old 04-10-2012, 02:02 PM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
I finished rebuilding my water pump today. The bearings and seals are available on eBay. While I had the water pump out, I drilled and tapped a 3/8 npt port for my heater outlet. This will give me hotter water for the heater and still allow the water temp sensor to be inside the water pump. On gibbons fix, I didn't like that the sensor was moved back out of the flow of the water through the pump.
I took this next pick to answer the FAQ: Which way does the upper thermostat go on my LT-1?
And here it is buttoned up and ready to go back in the boat.
Old 04-10-2012, 05:49 PM
Wow, that looks great. What made you decide to rebuild?
Old 04-10-2012, 06:38 PM
My bearings were shot, so it was rebuild or replace. An LT-1 water pump from inboardonline was $415, so I started looking to rebuild. I found the rebuild kit for $60 and ordered it. I later saw that the same guy was selling rebuilt pumps for not much more, but I'm glad I got the experience of doing it myself. I experimented a little with the paint job and cleaned up the impeller.
A rebuilt unit from Oreilly for a '96 Corvette is $140.00, so I guess I saved a little money over that option.
Old 04-10-2012, 09:21 PM
pram's Avatar
I got the kit installed last night
fired it up tonight no leaks so that is good
MONKEY FACE
