  #121
Old 02-11-2014, 03:11 PM
epnault's Avatar
epnault epnault is online now
Boat: 2016 ProStar 6.2L
Hmm. It looks like the 2 lines are routed (from each manifold) to the front of the engine. Am I seeing something wrong?
Old 02-11-2014, 03:22 PM
Table Rocker's Avatar
The rear steam vent has a long tube that runs up to the front of the engine. The hose attaches there (near the front) and goes to the right side manifold. The other hose comes off the water pump thermostat housing and runs under the K&N to the left manifold.
You can see on Pram's pic earlier in the thread where he has the tube from the rear capped off with a black cap and a hose clamp.
'96 ProStar 205 SD LT-1
Old 02-11-2014, 04:15 PM
mgs96ps mgs96ps is offline
Boat: A
Old 02-11-2014, 04:50 PM
epnault's Avatar
Thanks - do you recall where I can read more about the LT1 in MC?
Old 02-11-2014, 04:53 PM
Boat: A
Old 02-12-2014, 05:30 PM
Boat: 1997 prostar 205 lt1
1. click the search menu up top
2. click on advanced search
3. type lt-1 into keywords
4. select title only and hit search.
you need to have more than 3 letters in the keyword area for search so use a dash and type lt-1
Old 03-15-2014, 11:40 PM
Boat: A
Old 06-21-2014, 09:36 PM
Boat: A
Old 06-22-2014, 02:19 PM
Jerseydave's Avatar
TT Hero
Ok...did the cooling fix recently. Engine temp running the same, but noticed my original steam tube with rubber cap piece is ballooning up...so steam must be coming that way also. Should I be concerned?
I think you're suppose to remove the steam tube from the rear of the heads and install pipe plugs in each head. No need to have steam tube any more since you now have the fittings at the front of both heads.
Those steam tubes rust away and start leaking anyway, mine did.
I was njskier on here.
Old 06-22-2014, 05:52 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Mine are still there too. Any idea what plugs should be used?
1996 Prostar 205 LT-1
