Hydralic Steering on X-Star
Does anyone know if there is an adjustment on the sensitive of the hydralic steering . Mine seems a little hard to turn compared to one that does not have hydralic steering
Mastercraft 06 X-Star 8.1L
i have an 08 xstar with L18 and mechanical steering. my steering (as compared to my frineds 07 X30 LY6 with hydraulic steering) is easier and more geared down, i.e. -responsive. the only time my boat is even remotely hard to steer is when i am returning the wheel back from a hard/powered left hand turn. then some fluid dynamics kick in and i have to use both hands. i have not noticed any type of adjustment on my frineds system. could it be low on fluid?
"Tropic corridor, tropic treasure. What got us this far to this mild equator? We need someone, something new....something else to get us through" (James Douglas Morrison/The Doors) Last edited by Ole Miss Rebels; 07-17-2009 at 03:07 PM. |
No adjustment that I know of. Check your fluid level, burp system for air that's about it. Hyd steering units do require a little more effort than the std rack unit to turn.
I have asked the same question just recently, and have come to the conclusion that the hydraulic is just a little more stiff to steer, but I still have not filled mine with fluid, and purged any air out. I do think mine is a little low, just have not gotten around to it. It should not be hard to steer, just won't turn with one finger.
Be excellent to one another. |
Do you know where you check the fluid level. I have the little cap on the top of the dash. Is that just A vent
My previous boat had hydraulic steering. You could spin that sucker in a heartbeat lock-to-lock with one finger. When it got stiffer than that, it meant that there was something wrong with the pump. Fan belt, fluid level, pump failure.
I don't know about MC's hydraulic steering, but many of the power steering systems on boats have some water cooling, which easily gets overlooked in winterization, the result of which is the pump going TU.
'04 MariStar 230VRS/MCX |
This hydraulic steering has no pumps, no water cooling, no power. It is just hydraulic fluid in the line instead of a cable, IIUC. But I am sure there is no motorized parts to it.
I have a 2007 Xstar Salt water edition. The hydraulic steering wheel is very easy to turn and is very precise. Works great...
2008 X-Star with hydraulic steering. A bit more resistance than previous boats' cables, but not a big deal.
What is annoying though is that it takes a (very) small turn of the wheel for it to "click" over from one wheel rotation to the other. That is, it feels like a small gapping and, well, a bit ghetto. Is this normal and unavoidable on hydraulic steering, or do I need to check on fluid? Last edited by fbroen; 07-20-2009 at 10:51 AM. |
#10
My steering is solid...when turning left to right and right to left....check your hyd fluid...maybe low fluid or air in line....
