  #91
Old 07-09-2013, 08:43 AM
jkcTN jkcTN is offline
Boat: Current: 2016 X46 7.4L, Previous: 2007 X15 MCX350
I got the e2044 installed with out incident. 74.99 from advanced auto and I had a 5 dollar off coupon . One slight problem and wanted to see if you all have the same problem. With the new fuel pump installed it seems to take significantly longer to start the boat... my boat would usually start after turning over twice but with the new pump it is anywhere from twice to 6-7 seconds... every other time I go to start it it sounds like it's not going to start for a second.. while other times it fires right up. is this going to ware my starter out? Have you all noticed this problem with the E2044?
Sent from my Z10 using Tapatalk 2
Old 07-09-2013, 09:25 AM
André's Avatar
André André is offline
Boat: Prostar 190 1994
It did the same thing on my friend s boat after he replace the pump.
Turn out that his hose was leaking from the fitting and wasn t priming properly...
Work fine since...(4 years)
Keep skiing!!!
Old 07-09-2013, 09:31 AM
deminimis's Avatar
Boat: 2004 X-Star
Yup, leak at hose (guess). Mine took about 1/2 sec longer to crank at first, but even that went away over time.
Never Mind The Bollocks, Here's The X-Star
Old 07-09-2013, 11:15 AM
sand2snow22's Avatar
Boat: Ri257
We have had a couple come back this year One was e2044 the other was e2065 or e 2044, can't remember for sure. Both may have been run out of gas because they came in and the tanks were full....Might have received a bad batch. Replaced them with e 2065's. So far they've been good.
Old 07-09-2013, 11:27 AM
ttu's Avatar
ttu ttu is offline
does anyone know if they (mc) changed what pumps they are using. seems most of the issues have been with 2007 and older!
Old 07-09-2013, 11:32 AM
deminimis's Avatar
Boat: 2004 X-Star
Sandman, have you guys done a volume and pressure test on the 2065? I'm curious because the 2065 is designed for 1.8-3.0 ltr engines, whereas the 2044 is designed for a V-8 (albeit smaller than the ones we have in out boats). If it works, it works, but I'm just curious (just not curious enough to buy a 2065 and check it myself).
Old 07-10-2013, 12:55 AM
Boat: Ri257
No, good to know. I will order some 2044's but I know at least one has failed.
Old 07-10-2013, 03:59 PM
REDX2's Avatar
REDX2 REDX2 is offline
Boat: Mastercraft, X23 2016
Pep boys has the airtec pumps
Old 11-01-2016, 06:37 AM
ColoradoSteiss's Avatar
ColoradoSteiss ColoradoSteiss is offline
Boat: Mastercraft 2001 X-Star MX LTR 5.7L
Hi, it's been awhile since you good people have discussed this fuel pump thread, I'd like to know if anyone sourced the corrugated fuel line? Does it meet the SAE 30R10 rating?
I've got a new (for me at least) 2001 X-Star project and while changing the fuel tank's rotten gasket noticed the fuel pump assemble was missing all the screws holding the pump in the assembly... it appears they did a real hack job, pump replacement!
From what I've read on all these post, I am going to use an Airtex E2065 with SAE 30R10 hose (how long is it), does that sound like the correct move?
Old 07-08-2017, 01:31 AM
jamis0n jamis0n is offline
Boat: 2000 X-Star
I'm in the exact same boat (lol) right now!
@ColoradoSteiss - Did you figure this out? Any advice?
It seems clear which options there are for the pump, but what about the filter?
