Old 07-09-2009, 05:26 PM
mastercraftman
Posts: n/a
Trailer bunk help
Before you wrap carpet on the bunk do you apply any marine sealer or anything to waterproof the wood and carpet from getting rotted and moldy? What type of wood should I use that is durable and can get in a 2"x4"?
Old 07-09-2009, 05:28 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Regular old treated 2x4 works just fine. No need to seal it.
Old 07-09-2009, 05:35 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
And no need to use glue either. My recommendation is to use one strip of carpet to pad the top of the bunk. Then, wrap another layer of carpet around and staple with stainless staples to the bottom of the bunk.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 07-10-2009, 08:45 AM
TX.X-30 fan TX.X-30 fan is offline
Boat: mastercraft, X-30, 2004, MCX.
I have found that tanned cat hides last much longer than carpet, and they polish the hull with each launch and load.
Old 07-10-2009, 09:28 AM
damaged442's Avatar
damaged442 damaged442 is offline
Boat: 1989 Tristar 190, Indmar 351, 250HP
I used 3M spray adhesive to hold the carpet down. There are a few kinds out there, with different amounts of "stick factor". I probably didn't need to. With the staples, it's not really going anywhere. I just used pressure treated 2x6 from the Depot. I figured if the original bunks, which were not treated, lasted 20 years, these should last longer than I'll keep the boat. We'll see.
1989 Tristar 190 - Indmar 351, 250HP, 1:1, 580 hours
Old 07-10-2009, 11:06 AM
MC Hero
The only reason I mentioned not using glue is in case the OP or next owner ever has to replace the carpet. It's enough of a pain to remove a carpet that's stapled on. Glue just makes things stickier (yuk yuk).
FAQ
Be kind. Have fun.
Old 07-10-2009, 11:24 AM
Agreed, I use stainless screws for the cat hides.
Old 07-10-2009, 01:48 PM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
is it better to trap the cats or shoot them?
seems like shooting would be more efficient but it also messes up some of the hide
Say yes to cheap beer---- no to ethanol.
Old 07-10-2009, 02:12 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Ric just can't stay away from these trailer bunk threads...
Need LT-1 parts?
89058397 (pump outlet side)
Old 07-10-2009, 02:30 PM
Ric's Avatar
Ric Ric is offline
I know a thing or two about bunk
