Old 07-05-2009, 08:52 PM
apexer apexer is offline
Boat: 1999 prostar 190
99 Prostar 190 gauge problem
Need help,sometimes the gas gauge reads wrong,somtimes the oil presure reads wrong,somtimes the Amp reads wrong,somtimes the water temp reads wrong and sometimes the clock wont work and somtimes they all read wrong,where to start,thanks guys
Old 07-05-2009, 08:56 PM
Footin's Avatar
Footin Footin is offline
Boat: 1994 Prostar 205, previously owned 1991 Barefoot 200, 1987 Prostar 190
Bad ground run to the gauges.
OH-IO!
Old 07-05-2009, 09:29 PM
If you have a wide, flat black plastic box under the dash, follow the ground wire and make sure it was upgraded. They had a recall on that the first year and if the dealer didn't do it/the original owner didn't get a message or didn't take it in, it needs a better ground. IIRC, it needed to be disconnected from the MDC box, the ground wire cut and a new one spliced onto the harness (crimped and soldered), then run to the battery negative. All grounds reference to the battery negative, not the dash or the block. Use 14ga or 16ga (14 is better).
First, disconnect the battery and unplug the harness from the black box for a few minutes. Re-connect the harness and re-install the screw, reconnect the battery cable and try it. It may just need to be reset but if the ground hasn't been upgraded, do that/have it done.
Old 07-05-2009, 09:40 PM
I notice a wire was spliced in to the black wire that goes to the box,the other end goes to a small block with about 10 other black wires.what now,Thanks
Old 07-06-2009, 07:30 PM
anyone have a MDC box,sounds like thats it
Old 07-07-2009, 01:45 PM
ProStar Slalom's Avatar
ProStar Slalom ProStar Slalom is offline
Boat: 1984 S&S, 2001 19 Skier
Check with Jim or Chuck at BAWS. I had to replace the one in my 2001 a few weeks ago. I think I got their last one at the time, but maybe the've re-stocked. You won't find a better price.
