Old 06-26-2009, 11:23 PM
JMann's Avatar
JMann JMann is offline
Question fuel sending unit?
I just installed a new fuel sending unit in my 1991 PS190. It works but says I have 1/2 tank when I know it's closer to 1/4 or less. There are two little, what look like adjustment screws on the top of the sending unit. I assume one is the full and one the empty adjustment.
Do I want to adjust when full or Is there a sequence I should adjust them? Or should I not touch them and see what happens after a day on the water.
Old 06-28-2009, 10:33 PM
babymoore3's Avatar
babymoore3 babymoore3 is offline
Boat: 1988 Tristar 190
I have not seen a sender with adjustment screws. Generally there are mounting screws and positive / negative for the sender. The adjustment is usually physical by the height and length of the float arm (sometimes a bend) on the sender.
Kevin & Carrie
1988 Tristar 190
What do you think?
Change fiberglass accent from teal/green to lght/drk blue?
Take a moment and check this out!!!!
General Prayer Requests (Jesus Freak's page)
