Old 06-24-2009, 03:52 PM
Thomas1966
Idle surging problem
I have a 1993 prostar 205 with a 351 engine. Boat idle changes from 700 to 950 rpm's. Upon accelaration boat runs fine no problems, I have changed the fuel/water seperator, but that did not clear up my problem. Another friend thinks my backpressure could not be correct, which means I may need a new muffler. Does anyone have any suggestions?
Old 06-24-2009, 04:23 PM
GuitsBoy GuitsBoy is offline
Boat: 1992 ProStar 205
You can spray carb cleaner around the intake and carb to see if you have a vacuum leak, but more likely than not you just need to have the carb rebuilt. If youve still got the stock holley 4010, you way want to upgrade to the 4160 now. Its a much easier carb to tune and performs better on this motor.
Old 06-24-2009, 04:55 PM
mcmx2 mcmx2 is offline
Boat: 2005 TT 197 #77
My guess is that a power valve is out on your carb.
Old 06-24-2009, 05:29 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
I agree, went through the same thing last fall.
Charter Member Number 1
Quote: 2RLAKE,
Old 06-24-2009, 07:42 PM
flat broke's Avatar
flat broke flat broke is offline
Boat: 89 ProStar 190 & 74 Eliminator Flat Bottom V-Drive
carb ?
hey harold,
I have a 89 ps 190 351 1:1 how do I tell if I have a 4010 or a 4160 ? and what is the difference ? any info would be great thank you
Old 06-24-2009, 07:51 PM
Boat: Gone
Originally Posted by flat broke View Post
hey harold,
It should have a 4160 from the factory, unless a previous owner has changed it out.
4160 is single inlet fuel line @45 degrees on front bowl, port side,
Attachment 48688
4010 is dual line feed with inlets on front and rear bowls starboard side, with externally adjustable floats and side fuel level sight holes,
Attachment 48689
Old 06-24-2009, 09:01 PM
flat broke's Avatar
Attachment 48688
Attachment 48689
looks like I am good to go thanks for the reply and the great tech info
Old 06-25-2009, 08:28 AM
Why did MC change to the 4010 on later models anyway? Was it supposed to be a higher performance option? It has adjustable floats, dual fuel feeds and dogleg boosters, etc.
Old 06-25-2009, 12:37 PM
Boat: Gone
Apparently it was the decision of Indmar to use the 4010 on the 351 HO with GT40 heads that put out 285 HP.
Old 06-25-2009, 12:42 PM
Are there real world improvements over the 4160? So many of us have swapped out our 4010s for the 4160's. Im just wondering if were actually taking a step backwards.
