Old 07-07-2010, 01:33 AM
russlars's Avatar
russlars russlars is offline
Boat: Mastercraft 205, 1999, LTR
Sorry, I forgot to look forward a page. Glad you got yours fixed also!
1999 Prostar 205 with 330 HP LTR
Old 07-07-2010, 08:09 AM
Honkity Hank Honkity Hank is offline
Boat: Lyman 17' Runabout 1960 with 1960 Johnson 75hp, 2000 Pro Star 205
Originally Posted by russlars View Post
I'm pretty sure that is the old bracket and original alternator. When mine broke it was the bottom hole in the alternator which required a new alternator and then they added an extra bracket that hooks to the top bolt and another part of the motor for additional stabilization. I don't have a picture of the new style, but here is the picture of my alternator with the broken bracket.
On my boat the bolt failed not the alternator flange, a new grade 5.2 bolt was only 3 bucks or so, I am afraid that a grade 8 bolt might cause the flange to fail as in your picture. Your top bolt looks to be stamped as a grade 5.2.
I will order the bracket as it seems to recognize that the either a bolt or a flange will fail.
Old 07-07-2010, 09:13 AM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
So does anyone have a picture of the new bracket.
I dont think mine has the new bracket. and it breaks a bolt from time to time.
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 07-07-2010, 10:17 AM
hester's Avatar
hester hester is offline
Boat: 1999 Prostar 205
I installed the bracket several months ago when the lower flange/ear cracked like russlars.
New Boat - 1999 205 Blue/White LTR, Monster Tower
Old Boat - Red/White 1991 PS190, Tower, 351w & Powerslot
Old 07-07-2010, 11:42 AM
Does the bracket only reinforce the top connection? On my boat the top bolt is bigger than the bottom bolt (that failed) I was thinking the bracket would reinforce the lower end. Also on yours does the upper bolt go through the ear and thread into the bracket at the rear? I looks misaligned in the photo.
Old 07-07-2010, 01:20 PM
hester's Avatar
Yes, it only connects to the top only. The goal of the bracket as stated in the recall is to "eliminate the stress that occurs on the alternator mounting system during acceleration and deceleration of the engine or when the boat is being operated in rough-water conditions"
Yes, my bolt does go through and thread into the rear bracket. I'm not sure why mine is off center but the new bracket fit perfectly. Maybe the ear on the new alternator is shaped differently.
Old 07-07-2010, 10:13 PM
rem_pss308's Avatar
Thanks for the pic. I will be getting one if Baws has one
Old 07-11-2010, 04:59 PM
timvan's Avatar
timvan timvan is offline
Boat: none
Anyone know the size of the lower mounting bolt...the one that mounts the bracket to the block?
2002 Maristar 230 VRS
Old 08-03-2010, 05:13 PM
Did the bracket update on the 2000 prostar 205 this weekend. A big thanks to Chuck at Bay Area Watersports for sending the bracket (and a new glove box shock). The install was super easy, especially when I had my tool box (previous temp fix done with a short supply of tools). I did locktite the bolt on the alternator but not the water pump bolt. Did not have the right socket to torque to spec, will do that next time I take boat out, for now I just tightened down until I thought it was about 25 lbs, no telling what it truly is now.
Thanks again Chuck, appreciate the help!
Jeff - Atlanta
Old 08-03-2010, 10:34 PM
PT 1999 ProStar's Avatar
PT 1999 ProStar PT 1999 ProStar is offline
Boat: Mastercraft ProStar 190 1999 330HP Powerslot - 1st MC 1987 ProStar Current 2012 ProStar 197
Hey guys,
Good read this thread. I have a question does your water pump bounce around like crazy? I have a 1999 ProStar with LTR. I did get the new bracket for the lower part of the water pump which is a two piece connection. However my pump just seems to move way to much! Do you guys have this issue? It makes the boat vibrate alittle. At lower speeds and at idle is when I hear/see it the most.
Any insight? Am I missing anything?
Thanks
PT
