Old 05-30-2009, 09:56 PM
gomattgo gomattgo is offline
Boat: Mastercraft, X9, 2001, 5.7, 330 hp
High Oil Pressure
We just pruchased a 2001 X-9 with 54 hours on it. The oil pressure at idle is 55 psi, and climbs to a maximum of 80 psi with the engine running. I put a manual oil gauge on just to confirm, and it does idle at 55 psi, so I know it isn't the gauges. Is this something I should be concerned with? The manual says it should idle at 5 psi and at 2,000 rpms climb to 40 psi. Any help is greatly apreciated.
Matt
Old 05-30-2009, 10:25 PM
Craig's Avatar
Craig Craig is offline
Boat: Not a MC
There are plenty on here that will likely chime in that are far more knowledgeable than I am, but...
I would be far more concerned with 5psi as opposed to 55 or 80psi.
If it pegs your gage while running that may be a problem, way too much pressure and you could blow some seals, that is a major hassle. Maybe your oil level is high?
94 Prostar 190, LT-1, Powerslot [SOLD]
Old 05-31-2009, 12:00 AM
jixxxer's Avatar
jixxxer jixxxer is offline
Boat: none
I noticed on mine when im at almost full throttle or really get on it, the oil pressure jumps up to the 80 range and when i stop or slow down it goes down........???
Old 06-01-2009, 12:18 PM
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
i would verify that the oil is at the proper level. are these readings taken when fully warm or while cold?
Nate
Old 06-01-2009, 09:35 PM
rhsprostar's Avatar
rhsprostar rhsprostar is offline
Boat: 04 TT 197 (SOLD)
What kind of oil filter is on it? Why I ask is that once i changed to a high quality Amsoil filter my pressure increased significantly. Seems to be fine though. I have a friend with a Bu and has had the same experience with the Amsoil filter.
Old 06-01-2009, 09:40 PM
TX.X-30 fan TX.X-30 fan is offline
Boat: mastercraft, X-30, 2004, MCX.
At cruising speed mine has always pegged 80psi.
Old 06-02-2009, 10:21 PM
My mechanic said that 60-80 psi won't hurt anything, so I'm going to let it go. I just changed the oil and filter and it's still at 60 psi at idle. Thanks for your replies and help.
Old 06-02-2009, 11:29 PM
PolarBear's Avatar
PolarBear PolarBear is offline
Boat: GTR22 2001, 350Mag MPI
My 350 Mag MPI is usually at 40 but does go up to 80 at times. My coworker gear head said the same thing as your mechanic.
Old 06-03-2009, 10:29 AM
454Prostar190's Avatar
454Prostar190 454Prostar190 is offline
Boat: Mastercraft, Stars and Stripes, 425hp/454 Chevrolet, Actual Marineworld/Africa USA Towboat
Same for me
Old 06-07-2009, 06:03 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Same here....worry about it, but when cold (engine temp is 160 but I know oil is not completely hot) mine pegs at 80. Usually after running for a while it backs down a bit.
310 Predator
2004 Prostar 197, ACME 843
high oil pressure, low oil pressure, oil pressure
