Old 05-25-2009, 10:09 PM
CODY_YARBER07's Avatar
CODY_YARBER07 CODY_YARBER07 is offline
Boat: 1983 Mastercraft 19 Skiier Stars and Stripes
Send a message via MSN to CODY_YARBER07
Engine getting hot!!!
I just took my boat out for its first voyage of the summer and as I am idling out of the "no wake zone" I notice that the temperature gauge is almost in the red. I immediately turned the engine off and waited for it to cool down. After that I started it back up and drove to the houseboat with no problems. As soon as I get back to idle speed it heats up again. Not in the red but almost. Basically.. It only gets hot if you are idling. If you are going down the lake at speed then it runs a lot cooler than it usually does granted the water is still pretty cold. I have a feeling that it is either a thermostat or impeller but am not really sure and haven't checked either. If anybody has any clue what's going on here I'd love to know. My boat is an 83 S&S with the 351W. Thanks peoples!
1983 Mastercraft Stars and Stripes
351 With Powerslot
Old 05-25-2009, 10:13 PM
Bongo Bongo is offline
Boat: '89 ProStar 190; 351
I expect you are on the right track. In order, I'd check:
- Screen at transmission cooler (or similar) on intake hose. Debris in the screen that is forced through at speed, but not at idle? (Happened to me a couple years ago with wood chips - lot of sticks on the lake.)
- Impeller.
The thermostat is possible, but I wouldn't think it'd matter whether at speed or at idle. Maybe at speed there's enough force to get more water through a narrow passageway.
Good luck.
Bongo
Old 05-25-2009, 10:35 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Weeds blocking the strainer on the transmission cooler (easy to check), or a few broken vanes on the impeller (change it out anyway), or thermostat. I'd address 'em in that order.
'04 MariStar 230VRS/MCX
Old 05-26-2009, 01:25 AM
JDK JDK is offline
Boat: PS 205
I bet your impeller is toast.
The reason the engine cools down at cruise is the the circ. pump will pull enough lake water in at higher rpm, but it won't at idle.
Old 05-27-2009, 12:54 PM
Can someone tell me where this strainer is?
351 With Powerslot
Old 05-27-2009, 01:06 PM
It's on the intake side of the transmission cooler. Look at the output hose from your raw water pump. It goes from there to the intake side of the transmission cooler. The transmission cooler is a flow-through tube (heat exchanger). The transmission circulates tranny oil around the jacket while raw water flows through it on the way to the engine. If you remove that 1 1/4 inch hose from the lower in of the transmission cooler, you'll be able to feel the strainer and clear any material that may be blocking the flow of water from the raw water pump to the engine. Weeds blocking it may impair that water flow to the point where the engine doesn't get enough water to cool it. Checking for such weeds etc is a simple process of undoing the hose clamp, pulling the hose off, and sweeping your finger around in it.
Old 05-27-2009, 02:17 PM
bainez23's Avatar
bainez23 bainez23 is offline
Boat: 2003 x-2
impellar!!!!!!!!!
Old 05-27-2009, 02:45 PM
Might very well be the impeller, but even if it is, he still needs to check the transmission cooler strainer and clear it of broken impeller pieces. Might as well start there, especially since it's easier.
Old 05-27-2009, 03:27 PM
Rich-Atlanta Rich-Atlanta is offline
Boat: Mastercraft, Prostar, 1999, LTR 330HP
Check This
Cody, I had the same problem last year. The problem turned out to be the cover on the the impeller was worn on the inside and was loosing enough of its vaccume at idle to not pick up water properly. My problem was exactly as you describe yours as being. The engine would heat up at idle speed but as soon as the engine was above idle it would draw water and cool. I spent hours trying to figure out what was going on before taking it to a long time Mastercraft tech he had it figured out in about ten minutes. I think the cover was twelve bucks. Hope this helps - Rich
Old 05-27-2009, 05:35 PM
jwmiller jwmiller is offline
Boat: 2005 Prostar 1997
Drain plug
I just had an overheating problem this past weekend and it turned out that the drain plug on the transmission cooler had fallen out. No vacuum = no water.
engine, impeller, overheat, temperature, wakeboarding
