Old 06-02-2009, 06:27 PM
prostar205's Avatar
Boat: 2002, X30, L-18 Engine
Best adhesive for glueing swim step pad down??
One half of my swim pad came up over the weekend and I need to glue it back down. What would you suggest from re-glueing the rubber mat back down to my fiberglass swim step? I've already used liquid nails and that did not work too good.
Thanks for the help.
Old 06-02-2009, 06:48 PM
corey's Avatar
corey corey is offline
Boat: between boats
3M Super Trim Adhesive (Part number 08090)
Old 06-03-2009, 03:24 AM
GOLIATH
Posts: n/a
Had to do the same thing to my fiberglass teak this year. I did it while it was in storage because of the cure time. Heated garage comes in handy once in while! I took both mats completely off of the teak and sanded off all of the old adhesive. Got some texture to the back of the mats and on the fiberglass for the adhesive to grab on to....... and it worked great.
I used "3M Marine Adhesive Sealant 5200." After it cured, I then used a black caulk to seal around the outside so no water can get under the mats.
http://www.shop3m.com/60410009470.ht...KU=60980042877
Cure time is 7 days for the adhesive, but it is worth it. Had the boat floating in the water at the cabin for almost 2 months now and still see no sign of it coming off. I tried lifting up on the mats with pretty good force before I put the caulk on, and they are in place real good!
You can get the 3M Marine Adhesive 5200 at Home Depot or Lowes!
Old 06-03-2009, 06:46 AM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
You could try this, I use it on everything, including the carpet on the trailer bunks,
Attachment 48052
Charter Member Number 1
Quote: 2RLAKE,
Old 06-03-2009, 07:52 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
My problem was different - the black rubber insert was tracking black stuff throughout my boat from wet feet. MC replaced the pad under warranty, although what they did was give me the new rubber mat and some of the cyanoacrylate adhesive to glue it. That's the stuff they use at the factory to glue the stuff down.
The cyanoacrylate worked well, but I only had about 8 seconds to get the stuff down before it set up. No problems since install. I did run a bead of black 3M 5200 around the edge. Install detailed in this thread.
I do note that one additional problem with the fiberglass swim step is chipping along the bottom edge. I solved that with some edge trim I got from JC Whitney. I secured that with some Goop glue and it's held fine. The 5200 might have been a better choice, but no problems with the Goop so far.
'04 MariStar 230VRS/MCX
Old 06-04-2009, 01:52 PM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
you could try a product called SC2000
Old 06-04-2009, 02:21 PM
MattsCraft's Avatar
Thumbs up
Big Mac - Great addition, was thinking about adding something like that to my platform, we have a few skinned shins and ankles from the bottom edge of our platform, it is kinda sharp. I was worried that anything I added would just drag off in the water, this looks like a great option, thanks!!!
Old 06-04-2009, 05:32 PM
alex alex is offline
Boat: X-star 2004
Hi! Did the same thing this spring. The previous owner of my boat had done it, but bad so one side came off and the other was bumpy. So i removed both of them, cleaned off all the old glue/silicone. That was kind off a pain... After that I glued it back on with Sikaflex 291, which i spread out carefully with a fine comb used for tiling. I didn't want it to get bumpy again. I then applied i string around the edges which i then evened out with solvent. It came out very good, real sturdy, so i doubt it will never come off.
http://www.sika.com/industry/cmi-cus...ne-systems.htm
