Old 05-05-2009, 08:49 PM
Raobrien Raobrien is offline
Boat: x80
Is the center drain plug the only plug?
I recently bought a 2004 X80 with dual mcx's. I am currently fixing some issues on the boat. The main problem I have at the moment is I pull my drain plug (center) but any water accumlating in the engine compartments will not travel forward to the drain. I can not see a rear drain plug in the compartment or on the hull. What am I missing? Any help is greatly appreciated.
Thanks
Old 05-05-2009, 08:55 PM
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
Do not own an X80, but I have not seen any other modern Mastercraft that does not have a rear drain plug. No brass square bolt plug at the bottom center of the transom? The newer models are a black knurled plastic bolt.
You can download the X-80 manual from the MC main web site if needed.
2008 X star, 2005 X2
Old 05-05-2009, 09:00 PM
Boat: x80
My center plug is brass and I do see anything similar in the engine compartment. When I am under the boat I do see anything brass or black.
Old 05-06-2009, 11:37 AM
MC X-15's Avatar
MC X-15 MC X-15 is offline
Boat: 2008 Mastercraft X-15 SS
I am having the same problem, from what i understand there may be a drain plug on the transom. that unscrews from the outside. I may be wrong, havent been to my boat since i discovered this info. Let me know if it helps-bc i will be trying to solve the same problem this weekend.
Old 05-06-2009, 11:47 AM
Ben Ben is offline
Boat: '94 PS205 LT1
Assuming you meant "do not" see anything else bronze or black on the underside of the boat, that may be your only one. Can you lower the tongue of the trailer enough to get the water out? Other option is to park on incline, or on top of some 2x4's to get the tires higher than the tongue support wheel.
Old 05-06-2009, 11:59 AM
atlfootr's Avatar
atlfootr atlfootr is offline
Boat: Barefoot 200 MasterCraft 1993 ProV200 Outboard
Sorry I can't help ya.
As I only have one on my hull, lower rear under outboard.
Old 05-06-2009, 12:08 PM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
here is a pic of the transom of a 06 x80 i found online. does not appear to have a rear drain.
Old 05-06-2009, 01:15 PM
ViperRedX80's Avatar
ViperRedX80 ViperRedX80 is offline
Boat: 2005 Mastercraft X80
I have an 05 x80 and thier is not a rear drain plug. (that I know of) You can pull out the Speado that sits under the driver side engine.(placstic and only hand tigh so easy to remove) I also use this when changing the oil. Hope this helps.
Old 05-06-2009, 07:25 PM
Boat: x80
Thanks for the info. All is greatly appreciated. Will have to try the speedo trick.
drain plug, dual engines, mcx, x80
