Retrofit Fold Down Swim Platform Brackets!
I have been working in conjunction with Tim Creighton, (TT member XPC Sealman) XPC Bearings/Vesconite USA, Director of New Product Development @ OJ Props and Eric Johnson (TT member EJ OJPROP) of OJ Propellers on retrofit fold down swim platform bracket kit for some of the older boats.
The following pictures are of the prototype product as I installed them for a preliminary fit on our '89 ProStar 190. As it stands right now, the following boats can accept these fold down platform bracket kits that will be available through OJ Props and Mastercraft Boat Co. Availability, application, type of finish and pricing should be available shortly by Eric @ OJ Props, http://www.ojprops.com/contact_us and MasterCraft.
Kit shipped in a prop box, Attachment 53435 All the required parts, Attachment 53436 Platform with on OEM brackets, no room to walk behind, Attachment 53437 Removable platform brackets (2 bolts into 4 bolt block on the transom)(regular brackets bolt to transom with 4 bolts of the same pattern) with platform removed, Attachment 53438 Center transom brace with platform removed, Attachment 53439
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 07-31-2010 at 06:32 PM. |
Finally!!!!! Congrats Harold!!!!
Removable platform block on transom after 2 bolt platform bracket is removed,
Attachment 53440 Removable platform transom block removed and area cleaned up as best it could be and will be sealed and covered up later, Attachment 53441 Symmetrical fold down pins with .095"dia. weedeater line tethers, solderless connectors and vinyl caps on the ends, and spacer tubing to prevent rattling and loss, Attachment 53442 New fold down transom block, will be silicone sealed and old allen head bolts reused, Attachment 53443 New "U" fold down bracket bolted to transom block with pins/tethers installed, Attachment 53444
Fold down portion of the platform brackets installed on the "U" bracket and in up position, with the locking pins installed,
Attachment 53445 Fold down portion of the platform brackets installed on the "U" bracket and folded down for fit. Attachment 53446 OEM center brace with holes covered with vinyl non-skid pad, top and bottom and will still be used, but just for support of the center of the platform and not screwed to the platform, Attachment 53447 Both fold down platform brackets installed, Attachment 53448 Platform was positioned, new holes for screws marked, drilled and the platform was mounted to the brackets and as with the old brackets, no room to walk behind, Attachment 53449
Platform is now folded down and there is room to walk behind,
Attachment 53450 Once more, Attachment 53451 Everything has been disassembled, boxed up and sent back to OJ Props for clean up and to receive their finish. When they are returned to me, I will post pictures in this post of the final product installation. Man, this has been more fun than you can imagine! Thanks to Tim and Eric, you guys have your act together!
looks great harold.
and all this time i thought eric was sending you a case of teak oil ![]() |
#7
Thankfully you can now get a beer out of the fridge!
![]() Just kidding. Looks like a great option for anyone with those boats.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#8
Way to go #1
[>-----Ride'n The Wild West In A MasterCraft-----> |
#9
Looks great Harold!
I think he did this so that his wife can get to the washer and dryer easier! ![]()
If my words don't make sense, try reading them backwards. |
#10
Looks good #1,
I noticed that your floors a shade off from matching your teak. ![]() ![]() |
