Ballast Pump Problem
I have a 2002 MC x10 with stock ballast:
- My port ballast pump works fine both Fill and Empty
- My starboard ballast pump will work for Empty, but when the switch is set to Fill the light comes on, but the pump does not. After 30 seconds or so, the "reset" button on the bottom of the switch pops out.
- My center ballast (saddle) pump does not work for Fill or Empty. When the switch is set to Fill or Empty the light comes on, but the pump does not. After 30 seconds or so, the reset button on the bottom of the switch pops out.
Thoughts on issues? I'm thinking maybe the impeller, but that wouldn't seem to make sense on the Starboard pump as it works in one direction? I'm not much of a mechanic (but am looking to learn) so thought I would try to figure this one out on my own (before taking it to the shop).
Thanks for any insights!
