Prop Reinstall Directions
Installing prop. When I bought my ’03 X2, the prop was slightly bent (not really noticeable last summer) however, I put in the contract that the dealer would rebuild the prop for me. Due to when I bought the boat (mid-summer), I didn’t want to wait the few weeks for the rebuild right away and decided to hold it off till winter. I had the service shop who did the winterization take off the prop, however, I was going to have my buddy reinstall it this weekend since I’m out of town. So, I was looking for detailed directions on how to reinstall the prop…the more detailed the better. He wants to take it out this weekend after the reinstall, and I don’t want to get a call from him stuck in 60’ of water cause the prop fell off! Thanks
what i got from my local service shop was tighten it to 50 ft pounds put the cotter pin back
That's a lot of torque. I'd snug it up nicely with an extra 1/4 turn or so. Fifty ft-lbs is a heavy hand.
If you have a tapered propshaft, great info here.
http://www.correctcraftfan.com/forum...TID=12866&PN=1
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition The world is full of youth—what we need is a fountain of smart! |
I would definitely put anti-seize on the shaft where the hub sits. This will aid in removing it next time. I used it on my prop and also my raw water pump impeller. I was suprised how much it help on my impeller.
Boatless 'til I get out of school. |
[>-----Ride'n The Wild West In A MasterCraft-----> |
#7
I would grease the drive shaft and prop hub. Install, then tighten to 50 ft-lbs. I believe my 05 owners manual calls for 50 ft-lbs.
2005 ProStar 197TT, #28 of 100 Broken Bow, OK vacation cabin for rent - www.sipnskicabin.com PM me for a MC TT special rate. |
#8
The link above says specifically not to use anti-seize on the shaft if you have a tapered shaft (i.e. keyed shaft).
1996 Prostar 190, 350 TBI and Powerslot |
#9
The 03 X2 has a splined shaft (or at least the one I just sold did). The simple method we've used for years which never failed was to put a very light coating of marine grease on the shaft, hold one of the blades with one hand (block it against the hull if you have to) and tighten the nut with a standard 1/2" drive socket wrench. We've always used the German torque spec "good 'n' tight" and never had any issues. Use a new stainless steel cotter key each time if possible.
Where I've seen people get into trouble is when they block the prop against the hull and use a breaker bar or both hands to tighten the nut like a mad man. I'm sure there are more detailed procedures and specifications but this has worked for us for 20 plus years on both taper and spline shafts without failure. I seriously doubt any of us have used a torque wrench while changing the prop in the water at the lake. Last edited by bturner2; 04-01-2009 at 08:40 AM. |
#10
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
