Old 08-13-2004, 11:58 AM
blannan
Question Fuel Filters for 88 PS 190
I was under the impression that there are three filters: Tank, Seperator Filter and carb filter. Unless I'm having a HUGE brain fart there is no carb filter. The clear tube goes to a metal tube on the carb. No filter.
Does this sound right? SHOULD there be a filter or is this OK?
THANKS!!!
Old 08-13-2004, 12:43 PM
Knoxes
I wasn't aware there was a tank filter. In order from the tank up.... the separator then a canister mounted on the port side lower front of the motor. From there to the carb (4160), no more filters on my 88 PS 190.
Old 08-30-2004, 01:26 PM
PeteS's Avatar
PeteS PeteS is offline
Boat: 1988 Prostar 190 - 351 Indmar (1:1) / 365 Hours
I have a replacement for the fuel filter in the bilge area down low, but haven't had time to change it. Is it a simple job? Just loosen the bolt on top and pull? Or is there something special I should keep in mind. Will it be pressurized?
Thanks,
Pete
1988 Prostar 190 - 351 Indmar (1:1) / PerfectPass Digital Pro 6.5n, 13 x 12 Acme 3-Blade
