tracking fins on X2
At the risk of sounding foolish, Are there tracking fins on an X2? if not why not?
The X-2 does not have tracking fins as it has more V through the running surface than a conventional ski boat. Typically ski boats have a very flat running surface and thus needs the tracking fins for directional stability, the V in the X-2 hull does this on its own. The V allows the X-2 to have a much smoother ride in rough water, or even when driving through its own waves.
The new X-14V, which is based off of a ProStar hull does have tracking fins. FWIW the X-2, X-15, X-30, X-35, X-45 and X-55 do not have tracking fins. |
and... yea you can really turn the x2 over a bit if you try really hard but it's pretty easy for me (a 240 lbs+ guy) to turn any boat if i try hard... i couldn't see the fins helping much just from what i've seen from my buddys SANTE 210 which has fins... i can turn his just as much as mine
Current - '07 X2 blue on silver metal flake w/ switch graphics MY LED INSTALL... CHECK IT OUT MY WAKESIDE RIDE "It's just water... not concrete or dirt... so just throw it" -Parks Bonifay ![]() ![]() ![]() "I feel sorry for people who don't drink... when they wake up that's as good as they're going to feel all day" -Frank Sinatra ![]() "Indecision may, or may not, be my problem" -Jimmy Buffett |
I guess my next question would be: Then why does an x-star have tracking fins? dont the X2 and x-star adhere to the same basic hull design theory? ( just on a diffent scale)
Thanks in Advance! |
i would have to guess that's b/c the x2 is shorter and the "V" takes up a larger percentage of the hull... the hull on an X2 does flatten off in the stern but the ridge from the bow runs over half way length wise
ps you'd be crazy to try running the slalom course behind the X-80... the tower and the ballast tanks add on too much weight... stay light and crispy w/ the 280
Good Thinkin'
The X-Star and the X-2 have radically different running surfaces. The X-Star purpose built to have the best wake in the industry and it does it through what MasterCraft calls the AP-1 Hull. This hull looks to have a fair amount of V through the hull but at a closer glance you will see that the hull is very flat from about the drivers seat back where as the X-2 doesnt flatten out until a bit behind that.
The X-2 also uses a modified step hull, this is the triangular cutout on the side of the boat. The X-Star uses a different kind of step which basically makes the running surface narrower than other MC's. Though marketed as the Mini X-Star its more in quality of wake than how the wakes are achieved. |
