Old 05-10-2005, 07:12 PM
ski6at41off
Won't Start, just a click...
Hello all,
Have a 1994 Mastercraft PS190 w/ Indmar 310hp FI. Motor will not crank, just gives a single "click" which sounds like the solenoid activating, but wont crank the motor.
I have replaced the battery, the starter solenoid, tested the Neutral Safety switch, to no avail, and the motor is neither frozen or vapor-locked. The ignition switch SEEMS to be working, but dont know what voltages should be present between the posts in both start and accessory.
Any ideas ?? Bad starter ? Bad ignition switch ? Bad circuit breaker ?? What are the things to test each for and the tell-tale signs of them being bad ??
Thanks in advance !!!!
Old 05-10-2005, 07:33 PM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
if your skiing 6 @ 41 off, have someone else look at it , and work on that 43 pass!
Old 05-10-2005, 07:43 PM
Sledneck Sledneck is offline
Boat: MasterCraft, PS190, 1987, 351
Hammer.
Tap the starter w/ a hammer while some one turns the key..
-sled
Old 05-10-2005, 08:04 PM
Boat: 2017 PS
i used the hammer trick on my brendella in college for one summer. ( too broke to change it out at the time) .to minimize the hammer swings i would leave the boat on all day.
Old 05-10-2005, 08:06 PM
jsonova99's Avatar
jsonova99 jsonova99 is offline
Boat: 1991 Mastercraft Prostar 190
could be a weak battery, too. I've had the same thing happen in cars before.
1991 Prostar 190 - Ambush 4 blade prop
Old 05-10-2005, 08:20 PM
Since it only takes removing the wires and two bolts to get the starter off, do that and look at the shaft by rotating the starter gear. If you turn it one way, it shouldn't move. If you turn it the other way, it should climb up the shaft. If it won't turn at all, you know that it's frozen. If you want, take it to a starter/alternator rebuild shop. They can test it for you.
Old 05-10-2005, 10:55 PM
André's Avatar
André André is online now
Boat: Prostar 190 1994
Good one Rod!!! Ilike it!
Keep skiing!!!
Old 05-11-2005, 05:50 PM
ski6at41off
Thanks guys !! It ended up being just that the starter itself was corroded and dirty... cleaned it up and it fired right up.
Thanks again for all the help.
and if i COULD ski 6 at 41 off, i'd PROBABLY have a NEW Mastercraft, dont ya think ??
Old 05-11-2005, 06:36 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Yup, and I'm really in East TX.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
