Old 05-09-2005, 05:06 PM
MontanaMC
1987 w/powerslot prop
Bought this boat this winter and it had a 14x18 3 blade on it. Everybody told me it was the wrong prop! I put a 13x13 3 blade on and it is DEFINITELY not right (5500 rpm and 32 mph plus the valves were floating!!!!). What prop would be a good starting point? We are a mile high in altitude and are using the boat mainly for skiing and boarding with teenage boys.
Old 05-09-2005, 05:13 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Welcome to the board. If it's a slot, 14x18 sounds right, but I don't know for sure. As you mentioned, it's definitely not 13x13 as would be correct if it was a 1:1. Brad should have an answer for you if no one else does. He's got an 87 slot.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 05-09-2005, 05:56 PM
Okay, 14x18 is right. Here's another thread.
Powerslot Prop
FAQ
Be kind. Have fun.
Old 05-09-2005, 06:00 PM
sfitzgerald351's Avatar
sfitzgerald351 sfitzgerald351 is offline
Boat: 1984 Stars and Stripes Ski 19 w/ 454
If you are up close to 6,000 feet you might have to go down in pitch from the stock 14x18 for performance reasons because of the power robbing effects of the altitude. Ask around the local ski boat dealer to see what they say people are running or call ACME propellers or OJ to get their recommendation. But if you still have the 14x18, I'd put it back on and see how it performs. That will give you much more info to tell the dealers if it doesn't seem right. I think you ought to do about 42 at about 4.5k rpms in that boat. Hole shot should be good. You might have to sacrifice some top end for hole shot at that altitude though. At Tahoe (6,000') my folks had to prop down their I/O quite a bit to get out of the hole. Cost about 5mph at the top end.
Scott FitzGerald
1984 Stars & Stripes w/454
Old 05-10-2005, 08:14 AM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
I would suggest our 13.7 X 15.5 LC 1 1/8" 4-blade for your application. The standard propeller would be the 14 X 18. At the altitude you are running the 15.5 will allow the motor to run the proper RPM. If you have any other questions please let me know.
Thanks
Eric Johnson
Johnson Propeller
800-359-9730
Old 05-10-2005, 11:27 AM
Ah, altitude. Forgot to look at that.
Eric, don't know if you read the other post, but we got rained out on Sunday, so the prop test was postponed yet again.
FAQ
Be kind. Have fun.
