Old 05-09-2005, 10:51 AM
Knoxes
On dewinterizing, impellers and freeze plugs....
On it's first start since September, my 88 PS190 started right up, but I noticed there wasn't any water coming out of the exhaust, so I replaced the impeller, which was basically shredded. When I restarted it, two freeze plugs blew out. I'm pretty sure I did a good job draining the water out this past fall. Is there any other reason why they would come out, other than the block freezing up this winter? I'm in NC, and we had a pretty mild winter this year.
Old 05-09-2005, 02:16 PM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
The core plugs for a marine engine are brass so they don't corrode. Typically, the only thing that pushes them out is the expansion of water when it freezes. It is critical when you drain the block to completely remove the petcocks if your engine has them, and take a piece of stiff wire and probe around through the drain holes in the block to make sure that no sand, rust scale or other debris is blocking the hole.
Notice that I referred to them as core plugs not freeze plugs. Those plugs are in the block to plug up the holes that are used to remove the core sand from the block at the foundry. They are not designed to protect the block from the expansion of freezing water. I have seen many of freeze damaged blocks with the core plugs intact.
Engine Nut
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 05-09-2005, 05:19 PM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
Knoxes, where thehellhave ya been?
Originally Posted by TX.X-30 fan
Say yes to cheap beer---- no to ethanol.
