#761
2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula :
#762
Indirect
Do it indirect. Also, while others might disagree, put the meat out of the fridge and let it come to room temperature before you do the low and slow.
#763
So I'm heating up the BGE for steaks the other night. I let it get real hot and when I try to open it for the 1st time to throw steaks on it won't open. The gasket had melted with the lid closed. I got it open and threw the steaks on. My gasket is now toast but I'm not loosing any heat and it actually gets hotter now! Gotta love it! The guy at the shop had told me that some people actually use their's without a gasket. I will keep cooking until something changes!
#764
I have had my Grill Dome freeze before but never melt...
#765
suggestions
You will soon replace the gasket if you do any low and slow cooks or low tempts for fish and seafood. Good luck |
#766
#767
Gasket is shot on my BGE. I can't get the temp low enough for a long slow cook. Close, but not quite low enough.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#768
Give it a month I bet you will have no issue with it being too warm............. ![]() |
#769
The BGE gaskets should be replaced with an aftermarket job. I've put a Rutland on my Large and Small. Read the following for some info:
An explanation: http://www.nakedwhiz.com/gasket/gasket.htm Try this: http://www.nakedwhiz.com/rutlandgasket/gasket.htm |
#770
Just checking out Grills and have heard a Lot of good things about these grills , since you are using Hardwood charcoal , is it fairly quick to get a fire going and are these as good as they say they are, better than gas grills ? What size grills does everyone perfer ?
Mastercraft 06 X-Star 8.1L
