#121
Little family reunion this weekend - my sister brought an 8 lb tenderloin from Kansas City. Cooked indirect with the plate setter, temp at 400 degrees with a wirless thermometer probe in the thickest part. I pulled the meat off when the temp hit 137. Ten minutes' rest brought the internal temp up to 144 - perfect. While the meat was "resting", I grilled up some onion/cherry tomatos/red peppers, all tossed in olive oil with basil and garlic and I threw in some pepperoni slices - brushed with some garlic/lemon butter every now and then - grilled in one of those pans with a bunch of holes in it.
'04 MariStar 230VRS/MCX |
#122
sounds good! |
#123
Dog just bought one! Too bad I can't use it till I GET BACK FROM sTURGIS!!!!!!!!!
http://weathersticker.wunderground.c.../Brunswick.gif |
#124
try lobels of ny they cut your meat after you order it.Ship it unfrozen next day air on ice packs. Their meat is fantastic but very pricey. Try the hanger steak good price and a fantastic cut of meat. |
#125
Fellow Egg Owners,
I am doing a turkey tomorrow for a work function. It is a warm up for Thanksgiving. I have yet to do one yet. I have the vertical turkey roaster and the plate setter for indirect heat. I plan on smoking. I have some hickory chunks. My pals at the Outdoor Kitchen Store suggested I use 4 chunks. Apparently, you can oversmoke a turkey. So, has anyone done one? Any suggestions? |
#126
#127
#128
BAREFOOTING: I knew it was gonna hurt when I felt my arse cheeks hit me in the back of my head! ![]() !UOY NAHT RETSAF MA I TUB KNURD EB YAM I
#129
I would go buy a 5 gallon bucket from a donut shop or McDonalds (Frosting or Pickles) and clean it really good. You're going to brine the Turkey. You'll need some Kosher Salt, Two Gallons of Apple Cider (not juice) what ever other kinds of spices or herbs you want - boil some water and disolve 1 1/2 cups of Kosher Salt -- add this to about one gallon of cold water, you can add ice to cool the water off - once the water is cooled off (room temp at least) add the two gallons of apple cider to the gallon of saltwater (it also helps if you have the cider cold from the fridge) - add your spices, to the mixture, we also slice up a couple of granny smith apples for the soup - wash your turkey and remove all the bags (don't forget the neck) - once the turkey has been washed carefully set it in the bucket and let it fill with the soup, once it's filled then move it around to ensure the spices get mixed up with the bird in the bucket - put the lid on the bucket and move some of the beer out of your garage fridge and put the turkey in the fridge for at least 12 hours - after the turkey has set over night take it out and rinse off the outside and inside very well. Your Turkey is ready to cook I've tried the vertical metal setter, the ceramic vertical setter that actually holds liquid to help "steam" the bird from the inside and used the V-rack I've had the best results with the V-Rack sitting over a drip pan that was resting on the plate setter. Take your grill off, put the plate setter on the fire ring upside down then put the grill on the legs of the plate setter, V-rack on the grill Be careful that you don't get too big of a turkey or you'll need to adjust the depth of your dome thermometer so it' doesn't poke the turkey. As far as wood, for Turkey any kind of fruit wood will be best. Cherry or Apple would be prefered, I don't know how close the Orange orchard are to you but if you can get Orange wood, I'd substitute the apple slices for orange slices and use orange wood. As far as over smoking, keep in mind that the meat will only absorb the smoke up to a certain temp. Once the meat gets to around 100 degrees it's not going in any further than it has. The outside of the meat will continue to absorb it and that's where the bitterness comes from. You can just rinse a turkey and cook it and it will be better than any oven cooked turkey you've ever eaten. Brine it and people will be talking about you all year long, asking if you're doing the turkey next year. Trust the force Luke.... ![]() Last edited by Farmer Ted; 11-16-2006 at 07:32 PM. |
