Old 05-07-2005, 07:51 PM
aellicson aellicson is offline
Wiring for coil and distributor?
Hey guys,
I just put a new long block in my 75' prostar and boat and my dumbass can't remember how it was wired prior. What wires go to the coil(pos. and neg.) There is a wire that goes from the distributor to the coil also. Does this go to the positive terminal or neg.? I have two red wires(one I believe is the tach and the other ?) and an orange I followed back to the resister. I also converted it to electronic ignition(one red goes to + and black to - on the coil). Do I still need to run the other distributor wire to the coil? I was also told you need to bypass the resistor to get 12volts to the coil but the direction say not to. I tried looking at a wiring diagram but it does specify where they go on to the coil(-or+). If someone knows or could look on theirs it would be real helpful.
Good Skiing!
Andy
Old 05-07-2005, 08:20 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
Welcome
The positive side of the coil should be power coming from your ignition switch. The negative side should lead to the distributor. The tach connection is usually on the distributor side of the coil. The ignition systems with points used a resistor in the run position from the ignition switch. This was bypassed for cranking the engine in order to get a better spark when starting. You'd have to check the requirements for the electronic system you are using but in most cases the resistor is not needed with electronic systems
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
