Old 11-09-2008, 10:41 AM
wpauling's Avatar
wpauling wpauling is offline
Boat: X-Star, 08
Strut bearings/bushings or cutlass bearing
Just a quick post to show wear on a strut/cutlass bearing, shaft wear, and some of the changes MC has made in regards to the replacement bearing. The new one is larger in length and brass material shroud.
Just a reminder to the new owners, have your MC mechanic check your strut for alignment and possible wear per the prescribed maintenance schedule. The pics show the difference between the new and worn part, the third picture depicts the wear on the shaft, and the final pic is an orientation photo for those of us still learning.
08 X-Star
A boat load of friends and miles of glass sure play havoc on the summer honey do lists.
Old 11-09-2008, 11:33 AM
When did they change to a plastic bearing? A dealer should know that this should be checked whenever the boat is in for service and it's on the trailer.
Also, there is usually an upper bearing and a lower. The worn one was left in far too long and while I don't want to point fingers, this is one reason boat owners should take their boat in, occasionally. Many boat owners want to do their own service, for a variety of reasons but they don't have access to the same amount of information as a dealer's service department/tech. For this reason, some service steps are not addressed and can lead to failures of the boat's components and systems.
That shaft will be replaced, right?
Old 11-09-2008, 11:52 AM
wpauling's Avatar
Boat: X-Star, 08
Jim,
Not sure when they went from plasic to brass, but the MC mechanic showed me the difference when I had it in for the hourly services.
Watching what they have to do is quite a process. Too may things can certainly can affect other parts of the drive train system. I agree there is many items best left for the MC mechanics!
08 X-Star
Old 11-09-2008, 11:59 AM
wpauling's Avatar
Boat: X-Star, 08
Yes it was.
08 X-Star
Old 11-09-2008, 10:01 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
You have a 08 X-star..correct.
How many hours?
---Animal house
Old 11-10-2008, 08:22 AM
XPC Sealman's Avatar
XPC Sealman XPC Sealman is offline
Boat: N/A
Bearings
For those of you new to these strut bearings they are called Vesconite Hilube bearings. They are superior to the rubber/brass bearings of old. The traditional bearings needed a shaft diameter to bearing length ratio of 4:1. The Vesconite can handle a much lower ratio (even less than what is used). These bearings are very quiet and they are the premium in marine drive bearings. The photo shows a bearing that is in need of replacement without a doubt. I can tell you if it were a rubber bearing in that same position the shaft would have been shot! This boat had some obvious alignment issues. These bearings last longer, are easy on the shaft wear and are much quicker to service. The coefficient of friction on the rubber bearings is around .36 and this Hilube is around .09 this all relates to less friction and a smoother more quiet drive system. The difference in length is not an issue.
Old 11-10-2008, 08:32 AM
93Prostar190's Avatar
Yep. ..... the newer bearing is what came on my 08 PS214 ... so it looks like the dealer who did this repair opted to go with the more traditional brass and rubber setup. Both work well but both setups require proper shaft alignment to be within spec or unusual and premature wear will result.
2008 Prostar 214 MCX
Old 11-10-2008, 05:06 PM
wpauling's Avatar
Boat: X-Star, 08
How many hours?
I had 26-29 hrs on the boat at the time.
08 X-Star
Old 11-10-2008, 06:09 PM
"I had 26-29 hrs on the boat at the time."
That tells me the dealer didn't do everything on the pre-delivery setup list. Sorry, but I have a hard time with dealers who avoid such a major step.
Old 11-10-2008, 11:23 PM
TOO-TALL's Avatar
Thats Total B.S. Nothing should just wear out with only 29 Hrs. I would be pissed!!!
---Animal house
