Old 10-19-2008, 09:51 AM
Grover777's Avatar
Grover777 Grover777 is offline
Boat: 2001 PS 209
Heater and Shower Winterization
One more question....
Are there any special steps needed to properly winterize the heater and shower? The manual is less than descriptive.
Wishing spring was on the way!!!
2001 PS 209
2001 Prostar 209
1959 Glaspar Trident
Old 10-19-2008, 10:37 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
The heater needs to be completely empty of water, and IMHO should be full of RV antifreeze. First, drain the engine and exhaust manifolds and leave them open. Find the heater hoses lying in the bilge. One of them should have a double-barbed hose connector. If it doesn't, cut the heater intake line (the one coming off the intake manifold) and put one in. Disconnect the hose there and blow into the one that goes toward the heater core until you hear it blowing air. Then, pump some RV antifreeze into the whole heater core, so I use a hand pump such as they sell for pumping RV antifreeze through RV water systems. Takes about a half-gallon IIRC before you hear the antifreeze coming back into the block from the return line. Reconnect the heater hose and you're done.
Those pumps are available all over the place (Amazon, for example) or at virtually any RV store. They're about $15. Google or look for "RV winterizing pump".
As to the shower, disconnect both the hot and cold hoses at their water source and put them in a gallon jug of RV antifreeze. Then turn on the shower hot and cold until antifreeze comes out the shower head.
Please make sure you use RV antifreeze (propylene glycol), which is considered non-toxic. It comes in -50 and -100 versions. The -50 stuff will slush up in your home freezer. I live in Minnesota, so I use the -100 stuff.
'04 MariStar 230VRS/MCX
Old 10-24-2008, 12:14 AM
magnum's Avatar
magnum magnum is offline
Boat: Mastercraft X-Star 2006 L18
Big Mac, Where on the manifold are the plugs, I see on one end were the hoses are connected but I don't see plugs on the bottom side to drain them , I have the 8.1L engine , also it says in the manual , make sure on this model to remove the Knock Sensor, Is this the little fitting on the engine block where one of the engine plugs is screwed into ? thanks
Mastercraft 06 X-Star 8.1L
Old 10-24-2008, 05:04 AM
The exhaust manifolds need to be drained by disconnecting the hose that connects the two together, and by removing the brass plugs, one on each, that are on the botton side of the manifold, toward the front of the engine usually in front of that connecting drain hose.
On some model engines (MCX), the knock sensor is in one of the block drain holes (the one on the right side) and therefore has to be removed to drain the block. IIUC, the knock sensor on the 8.1 isn't in a drain hole - it's in it's own little fitting that isn't a drain hole and you still have to remove a brass plug from each side of the block. AFAIK, there's no point to removing the knock sensor for winterizing an 8.1 liter Indmar engine.
Old 10-24-2008, 09:27 AM
JohnE's Avatar
JohnE JohnE is online now
Boat: 40th Anniversary X14
Bigmac, if you blow out the heater core with a compressor, why do you still feel the need for antifreeze? I'm not doubting or challenging the thought, just looking to understand.
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 10-24-2008, 10:21 AM
Actually, I don't blow it out with a compressor, I use lung power one one hose until air comes out the other. I use antifreeze because the heat exchanger passages are small. So you get most of the water out except for a few drops. Those drops coalesce into one big drop and that falls to the bottom of the core. That drop freezes and ruptures the aluminum tubing it was sitting in. For about $5.00 for some -100 antifreeze and 5 minutes of my time, I can decrease even further the chance that I'll have to go through the PITA of changing a heater core.
Old 10-24-2008, 03:11 PM
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
Good point Bigmac. I never thought about how little water it would take to freeze and burst the exceptionally small network of openings in a heater/radiator core.
2008 X star, 2005 X2
Old 10-24-2008, 03:19 PM
Roonie's's Avatar
Roonie's Roonie's is offline
Boat: 2007 MC X2, RTP-1 5.7L 310 HP 1.5:1, 14.25 x 14.5 XMP OJ Prop, bimini, depth finder, and table, teak platform, White/viper red
+1 on the -100 stuff. I used -50 in my toilet bowls at the cabin and came in during a cold spell and they were all frozen.
Old 10-24-2008, 04:11 PM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
Bigmac, instead of using air to push the water out, what if you used a wet/dry vacuum to suck out all of the water in the heater and shower systems ? would that do any harm to them ? what kind of possible damage would be done if you used a vacuum to get out all water from the engine ? thanks for your input.
Old 10-24-2008, 05:16 PM
Dunno why that wouldn't work, as long as the pressure didn't get negative enough to collapse any of the aluminum. Auto radiators can take at least +1 atmosphere, but these hydronic heating systems in our boat heaters aren't designed to be pressurized. I don't know how much pressure, positive or negative, it would take to burst or collapse the heat exchanger. I'd be careful.
