Old 10-19-2008, 08:46 AM
Grover777's Avatar
Grover777 Grover777 is offline
Boat: 2001 PS 209
Fog EFI Engine?
Hi:
Do I need to fog an efi engine? If so, what is the proper procedure?
I have a 2001 PS 209 with the 330hp LTR engine.
Thanks!
2001 Prostar 209
1959 Glaspar Trident
Old 10-19-2008, 09:25 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
These threads may help, http://www.google.com/cse?cx=partner...+EFI&sa=Search
Charter Member Number 1
Quote: 2RLAKE,
Old 10-19-2008, 09:55 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Originally Posted by Grover777 View Post
Hi:
Thanks!
Yes, you do. Carburetor vs EFI makes no difference relative to the need to fog the engine before layup.
Pull your spark arrestor and with the engine running, spray fogging oil into the intake. The engine will bog and white smoke will come out the exhaust. I do this as the very last step in the winterizing process, and after several cycles of spray-bog-spray-bog, I spray into the intake until the engine actually dies.
Don't trust that the little red straw on the fogging oil can won't come loose and shoot into your engine.
'04 MariStar 230VRS/MCX
Old 10-19-2008, 11:01 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I don't know if the LTR is a "dry intake," but if it is, from what I've read about my non-indmar engine, you may not want to fog it at the intake. Rather, you would fog the cylinders (remove the spark plugs and spray fogging oil into the chamber) and then turn the engine over a few turns by hand. Again, this may be a PCM specific instruction, but it may be worth investigating further before you fog the intake on your engine.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 10-19-2008, 11:09 AM
Grover777's Avatar
Boat: 2001 PS 209
Thanks! I will dig more and see what it takes for the LTR. I did the TMC Google search and did not find much for LTR.
2001 Prostar 209
Old 10-19-2008, 12:34 PM
OhioX14's Avatar
OhioX14 OhioX14 is offline
Boat: Mastercraft, X14, 2008, MCX
On newer engines there seems to be increasing reasons NOT to fog through the intake. On my MCX Indmar specifically warns against it as it can get into the catalytic converters and cause damage. There's also the EFI dry intake concerns and my dealer has warned me about that.
I'm a firm believer in changing the oil during winterization and really don't see the need to change it again in the spring. However, if you fog each cylinder and that stuff makes it's way into the oil pan I would feel compelled to change the oil again. Therefore, why bother? I never fogged my GT40 prior to purchasing my first Mastercraft, I know quite a few people who don't fog, and I don't plan on doing next year when I start winterizing my own boat again. There seems to be more reasons against it than there are for it.
Old 10-20-2008, 08:44 AM
wpauling's Avatar
wpauling wpauling is offline
Boat: X-Star, 08
My dealer gave me the same warning/concerns when we talked winterization on my MCX Indmar engine.
08 X-Star
A boat load of friends and miles of glass sure play havoc on the summer honey do lists.
Old 10-20-2008, 09:08 AM
Scott's Avatar
Scott Scott is offline
Boat: 2012 Mastercraft X-30
I have to ask this?? My Master Craft dealer leaves the spark arrestor on, starts engine and sprays fogging oil through the arrestor.. Is this cool??
Old 10-20-2008, 09:33 AM
Boat: Gone
Sounds like a little lazyness and if there is any dust, trash on the flame arrestor it could be dissolved during fogging and pulled into the intake.
Old 10-20-2008, 10:38 AM
I don't think so, but the magnitude of its badness depends on the material of the spark arrestor. If it's a metal element, probably not too bad. If it's a K&N paper element, it's very bad.
