Old 10-01-2008, 01:19 PM
boatweight's Avatar
boatweight boatweight is offline
Boat: Prostar 190, 1996, LT1
Send a message via Yahoo to boatweight
Question Red stripe under engine cover, hmmm
Last weekend I was doing my year end prep to put my boat (1996 ps190 LT1) in storage, sad day but it's getting cold here in Idaho, and I noticed a red spray stripe on the inside of my engine cover. I am assuming that the transmission fluid is leaking from the drive shaft seal, spraying in a circular pattern when put in gear, but I cannot find any major leak so this might be happening at higher speeds.
Anyone have experience with changing the seal? Is it a big job that should tackled by a mechanic or a handy guy with tools?
thanks for the help. Lee
Boatweight
1996 PS 190 LT1
Old 10-01-2008, 02:02 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
I have had the trans apart (and back together successfully for a couple years now!) on my 98 with an LT-1. I did not have to replace the output shaft seal. Good thing, because the nut that holds the flange onto the output shaft of a ZF Hurth is a VERY unique design. That means you would need the VERY special socket to remove it.
If I were you, unbolt the drive shaft and take a look at what I am describing. If yours is the same design as mine you might to consider paying to have the repair done...
Need LT-1 parts?
89058397 (pump outlet side)
Old 10-02-2008, 04:38 PM
boatweight's Avatar
Good to know, I am going to try and tackle this project next Spring. Thanks for the help
Boatweight
1996 PS 190 LT1
Old 05-19-2009, 09:57 AM
boatweight's Avatar
Need to deal with the leak
Well I finally pulled my boat out of storage and remembred that I still have a leak. I was able to confirm that the leak is happening at the seal, see picture, so from your thread I am assuming this is not an easy fix and it would be wise to have my MC shop give it a look. I do have a friend who is a mechanic and is willing to put some time in for some time on the boat--always a good trade. Any idea what kind of parts and time we are talking about, you also talk about a special socket
Thanks for the help.
Boatweight
1996 PS 190 LT1
Old 05-19-2009, 10:49 AM
ntidsl's Avatar
ntidsl ntidsl is offline
Boat: 2005 197 TT
I love Red Stripe! Just make you feel like you are in Jamaica!
2 at 32' off 34 mph PB July 2006
Old 05-20-2009, 10:02 AM
boatweight's Avatar
I will make sure that I have plenty of Red Stripe on ice when I try and install the new rear seal. I think I will need it!
Boatweight
1996 PS 190 LT1
leak, transmission
