Old 05-01-2005, 11:19 PM
Medicine Laker
Cold nights and engine blocks
I live in the north and like to get my boat in for some early season skiing. I have been warned previously about the possibility of having the water freeze in the engine block and and it cracking. How cold does it really need to get before this is a concern? Just because it gets down to 32 for an hour overnight should not be a problem, but where is the line?
Old 05-01-2005, 11:30 PM
Leroy
No one can answer for sure, keep in mind the temperature also varies by probably +/- 3 or 4 degrees depending on where the boat is located.
I would play it safe, if you make a mistake it is at least $5k mistake. It's easy to drain the water out and not more than a 10 minute job.
Old 05-02-2005, 12:24 AM
Bongo Bongo is offline
Boat: 2004 MasterCraft 197 TT
Yea, I've thought about this question a few times. My rationale: If the boat is on the water, the lake will act as a 'heat island' and not get as cold as the air over land. However, it'll also be at the low point, so offset some by the cooler air gravitating toward the low spot. When temps dip slightly below freezing - especially if was a (reasonably) warm day - I have no concerns. Beyond that, I've occasionally taken my chances.
If you are concerned, you may want to try a small light bulb. An incandescent light bulb is basically an electric heater that emits a small bit of light energy. Placing a well-protected light (i.e. shop light, or similar) under the engine will certainly keep it warm enough on most spring nights in most locations. Notice the wiggle words, such that I didn't give a definitive answer? ;-)
Bongo
Old 05-02-2005, 12:30 AM
JEREMY79's Avatar
JEREMY79 JEREMY79 is offline
Boat: 1979 stars and stripes
Dont forget that metal temp (block is metal) is typically 10-15 degrees colder than the air. I know this because of painting metal. Stupid stuff that stays in my head.
#1 supporter of wadka
Old 05-02-2005, 12:55 AM
erkoehler's Avatar
I wouldn't take the chance. Either drain the block, or pull the boat out of the lake and store it indoors.
To me, the 15 minutes it may take to do either of those things is not worth the 5k in possible damage.
Old 05-02-2005, 01:06 AM
AirJunky's Avatar
AirJunky AirJunky is offline
Boat: Former Prostar 205 owner upgraded to an 05 Malibu vRide
These inboards are a lot easier to drain than an outboard or I/O. With petcocks on the side of your block, a pair of hoses connecting the exhaust manifolds, and a couple of radiator flush Ts in your heater & shower hoses, bump start the motor once & the water in the motor is gone in less than 3 minutes.
I have been keeping my 205 outside for 5 years & I live less than an hour from the Canadian border. Never had a problem..... knock on wood.
Bill
-former '94 PS205 owner. Still ridin my Sky Ski.....
Old 05-04-2005, 07:27 AM
Tom Jones Tom Jones is offline
Boat: 2004 PS197 w/310TBI previous 1994 Prostar 205 w/LT1
I agree, you have to remember also that the motor box has insulation around it and if the boat has been run the day before the temp. drops it will be fine even if it gets quite a bit below freezing. Just for piece if mind I do put a trouble light inside the motor box occassinally when it gets more than a couple of degrees below freezing. I do this if the boat has not been run that day.
Old 05-04-2005, 11:03 AM
wiltok wiltok is offline
Boat: 2001 X-9
I have been told (and this makes sense) that if the boat is stored on a lift over the water - you will be less affected by the cold. The heat is released from the lake and keeps tempuratures warmer around the boat (unless of course the water is frozen . The warmer the water the better - obviously in the fall it would be like having a huge heater under the boat. However, the effect still exists in the winter. Just my opinion though - don't sue me if you get your block cracked!!
Old 05-04-2005, 11:07 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Regardless of where you store it, I'd say that draining it and spining the motor with the kill switch removed for a second will be your best bet. If you don't, to an extent depending on where it's stored, you're rolling the dice.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 05-04-2005, 11:10 AM
sizzler's Avatar
sizzler sizzler is offline
Boat: 1995 barefoot200;;;2004 X9 MCX
[quote=Tom Jones]I agree, you have to remember also that the motor box has insulation around it and if the boat has been run the day before the temp. drops it will be fine even if it gets quite a bit below freezing. Just for piece if mind I do put a trouble light inside the motor box occassinally when it gets more than a couple of degrees below freezing. I do this if the boat has not been run that day.[/QUOTE
tom jones.....does this happen a lot???
"ITS NOT UNUSUAL"
sorry couldnt resist
KEEP YA TOES UP!!!!!
2004 X9 MCX ALL BLACK
http://www.prwb.net/tallington/index.php?id=12
nice older x-boat at berth in the advertisment above
