  #31
Old 03-15-2009, 08:11 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
According to the manual, closed cooling was an option.
Just for the record, the 1987-91 TriStar manual lists the following options:
- Power Slot Package
- Fresh Water Cooling System
- Boat Cover
- Trick Release
- Heater
- Tonneau Cover
- Sun Top
"Fresh Water Cooling System" is a confusing term isn't it? At first it sounds as though it would be the same as "raw water." The manual describes it:
-The fresh water cooling system is self-contained and consists of a water to water heat exchanger, reservoir and interconnecting hoses. Water supplied by the raw water system removes heat from engine coolant in the heat exchanger. The engine water pump circulates coolant throughout the system."
I have a whole file of TriStar pics but only one or two have FWC as I recall.
Old 03-15-2009, 09:20 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: 40th Anniversary X14
Originally Posted by PacMan89 View Post
Are tristars supposed to have a closed cooling system and use collant?
I don't think so. Not on my 88 anyway.
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 03-17-2009, 11:49 AM
pkskier's Avatar
pkskier pkskier is offline
Boat: 1987 & 1989 TriStar 190
They are not supposed to have a closed cooling system, but it was an option.
1987 & 1989 TriStar 190 Red & White
Ski Yesterday, Ski Today, Ski Tomorrow
Old 03-18-2009, 01:38 AM
wheelerd's Avatar
Boat: 2005 X2
Here are two pics of a closed cooling system from an 88 TriStar from Tucson that was on Ebay last fall.
Old 04-03-2009, 03:57 PM
nostar 190 nostar 190 is offline
Boat: m/c prostar 190/ 1995 265 hp tbi/powerslot trans
Originally Posted by TMCNo1 View Post
Hi, can anyone vouch for "Jim the man" ? I have some stitching that needs to be redone & would like to have him do the work if he is that good & reliable.
Old 10-20-2012, 07:41 PM
sub_squoch sub_squoch is offline
Boat: 1988 Mastercraft Tristar 190
I hope you are all still out these cause I have questions! I have a 1988 Tristar 190. When I bought it there was a custom built, permanent sundeck with a 750 fat sac plumbed in under it. I love the sundeck but could really use the seat space. I would like to make a convertible sundeck and still have the sac plumbed in under it. I have figured out a way to do this but it will end up making a pretty high back seat when it's in the seat position. It would be ideal if I could bury the sac in the floor but the boat has an elevated floor in the back where the seat sits that makes things a PITA (as a few of you have mentioned!). Does anybody know what is under that floor section? Can I cut it out and make the floor level?
Old 10-21-2012, 02:47 AM
wheelerd's Avatar
Boat: 2005 X2
Some of us all still here -- we have no life! lol
You might want to start a new thread on this as it might get more attention.
Anyway, to answer you question, I'm not sure why the floor was raised at the stern. Perhaps to create clearance for the tiller? Or maybe something to do with the integral swim platform. I don't know. In any case I'd be wary of cutting it out and leveling it as it might seriously affect the structural integrity of the hull.
Old 10-21-2012, 10:13 AM
staceyr's Avatar
staceyr staceyr is offline
Boat: 1993 Mastercraft, Prostar 190, 285 hp Indmar 351
I am looking for drivers seat to go in my 93 prostar, some of the members found this for me just wrong year. Looks like it would work for you.
http://www.ski-it-again.com/php/skii...c&postid=16663
Old 12-21-2012, 03:21 AM
lakeoz tristar's Avatar
lakeoz tristar lakeoz tristar is offline
Boat: 1990 Tristar 190 and 1998 Baha Cruiser Mach 1 290
I am not sure of anyone is still out there that has replaced their carpets..But I am in process..I did get the walk through board out and there was wood in that section and I had to removed it because it was all spongy... Got that part figured out.>Bit just in front of that section there is a V section that is at the very front of the boat that sits under the front seats.. How Did you get the carpet under that section???? I was thinking that if the replacement carpet I get matches the color pretty close I can just do that little section and leave all the carpet under the bow seats that is not visible, but I am not sure what to do and how to do it? As you can see from my pics its the only carpet left in the front of the boat that I am scratching my head on how to replace it? And the spongy floor with rotted wood.
Old 12-21-2012, 11:28 AM
wheelerd's Avatar
Boat: 2005 X2
It's been five years since I did my TriStar carpet, but as I recall I cut out the front triangle bit from inside the underseat storage compartments where the seam would be hidden. I was able to slide the new piece under the seat base. I may have used the jacks under the dash to help gain a bit of clearance.
190, 1988, interior, mastercraft, tristar
