Floors
I am unsure at this time what the panels are made of. I haven't had them out for 4-5 years. I am curious to what I have to do if I want to replace some of the floor boards. If it would be as easy as taking the old ones out and cutting new one from the old template. I know there was another thread on here awhile back where a guy redid the floors but I can't seem to find it. When I tackle this job this spring I will try and help but I now that doesn't help you now.
#22
The wood isnt showing when you remove the panel and flip it over. The wood is fiberglassed into the bottom of the panels and rots over time causing the floor to get soft and springy. I cut around the edges and was able to chisel out all of the wood and replaced with cdx plywood (that's what was in there) and plan on re-fiberglassing when it warms up outside. Still looking for some instructions on how to remove the front panel. Can anyone help?
#23
Which front panel?
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#24
If you look back at the pics in Post #13 it's the square floor piece that is in the walkthrough.
Just got my carpet from Overtons the other day and my upholstery is all being done as we speak, so I can't wait for it to warm up here and get at 'er. The floor panels that I do have out all seem solid so I won't mess with them.
"For every complex problem there is an answer that is clear, simple, and wrong." (Henry Louis Mencken) 2005 X2 Viper Red, MCX, Acme 1285, PPass (previous) 2001 X5, 1991 TriStar 190 |
#25
My floor is all fiberglass. I imagine yours is also. As far as I know, no wood was used in the floors (specifically the stringers) since the mid 80s. If you have some flex in your floor one of the removable centre panels may have a crack and may just need some reglassing underneath. You were asking about carpet cost.... I've just ordered 18 feet of the 8.5 foot wide Daystar Lancer 20 oz. carpet from Overtons. They sent me a sample card with all the colors on it and the Light Grey was an exact match to my current carpet. I sketched out all my pieces to scale on graph paper to make sure I ordered the correct amount. Is your boat an open bow? If so, do you have the square center floor piece that sits right in the walkthrough area? As you can see in my post above I'm stumped as to how to get this piece out. Judging from the photos above mastercrafttristar 190 was able to somehow replace his carpet there.[/quote] I have an open bow and to get that peice out i jacked the left dash peice up and two of us were pulling it. I took some effort to get it but we did. These are the pictures that i could find of that section. ![]() ![]() ![]() ![]() Thanks |
#26
Hey there mastercrafttristar190! Thanks for posting. I tried PMing you awhile ago but I guess you have that feature turned off.
Since I know now how you got that front floor piece out it will make my (and TRISTARXs) job simpler. Where did you actually place the jack under the dash? I can sort of judge from the pic that it was pretty close to the center but can you recall where the contact point was under the dash? How many inches did you lift it? You must have held your breath waiting for a "snap" of fiberglass!
#27
To tell you the truth I really dont remember where I placed the jack. All I remember is it was on some strong piece. As for the lifting I think it was around 1-2 inches that I raised it but just keep lifting it a little bit and pull it. Every time you pull it it should move out of it place. I took some effort to get it out of there though.
#28
That's helpful. Thanks.
I'm assuming then that when you lifted the floor section you slid it sideways to port and then back to clear the fuel tank filler neck? At least that's the way my tank is. It's the reason I can't just slide the floor section straight back.
#29
I got my front floor panel out today! I tried what mastercrafttristar 190 suggested. It just about worked but the floor panel kept binding against the starboard dash floor support (ie. the side of the walkthrough where it attaches to the floor.) So, I jacked that side up a bit also. With the extra clearance I was able to lift up the left side of the floor panel, slide it a couple of inches to port and then back towards the stern to clear the fuel tank filler and vent necks.
Now, once it really warms up here I can rip out the rest of the carpet and get the new stuff in.
#30
Are tristars supposed to have a closed cooling system and use collant?
| Tags |
| 190, 1988, interior, mastercraft, tristar |
