Splined shaft or not
I recently purchased a 1998 Prostar 205 and am a newbie. I asked the board a question a short while ago and got a great response. Well I have another that I need help on. I ordered a new prop from my dealer to replace the existing but ragged 4 blade ( no idea if it was original). The dealer finally got one in from ACME but it was 3 blade, splined 1 1/8 inch shaft. I know that ACME says you can use their 3 blade and get the same smoothness etc as a lesser quality 4 blade but
1) do you think that's true? 2) since my boat is in the water for the summer I havent gone under it to try and check shaft specs so is splined and is 1 1/8 inch correct? 3) is it important to get a new nut when I replace the prop? Thanks in advance for any help here ( also I do not have hole shot trans) |
ACME will outperform any other prop on the water.
Ok thats my sales pitch. PTX9 |
I would think that information would have been provided to the dealer by you as to whether you have a 1:1 transmission, 1"shaft or 1:5 PowerSlot transmission, 1 1/8" shaft, by looking on the top of the transmission at the Borg Warner ID tag and you should have a tapered shaft, not a splined shaft.
I suspect what you were sold may be all wrong, but you'll have to figure that out and get them to get you the correct prop if it's wrong.
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
[quote=oldboater;527610
3) is it important to get a new nut when I replace the prop? Thanks in advance for any help here ( also I do not have hole shot trans)[/quote] It's your choice to reuse the old nut, but I normally replace mine with a new key, Nyloc nut and cotter pin. Your dealer may carry the keys, nuts and cotter pins, or you can buy them locally from fastener store or here, nut, http://www.skidim.com/prodinfo.asp?number=NUTNYLBR3410 and cotter pin, http://www.skidim.com/prodinfo.asp?number=COTTER16X15 , key, http://www.skidim.com/prodinfo.asp?number=KEYBR25X2
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 08-10-2008 at 09:53 PM. |
Next time, or maybe even now, contact Eric here, http://www.ojprops.com/ and be prepared to give him all the correct info about your boat and how you will be using it, skiing, wakeboarding, surfing, with or without ballast and how much ballast and he will advise you on the spot and aid you in getting the proper prop for your boat the first time.
It's your choice!
thx for the responses. I do not have the powerslot trans. is there any chance that it coule beb a splined shaft if it is the standard 1:1 trans.?
#7
Your going to have to go look at the shaft to see for yourself. A newer splined shaft may have been installed for some reason, but I seriously doubt it. Besides, the splined shafts are 1 1/8" for all of them as a standard feature now.
#8
PS, if by some chance the shaft had been changed to a splined 1 1/8", the transmission coupling/couplings, shaft log/stuffing box and strut would have to have been changed also and I suspect that would mean the boat has had some major damage for that to happen. I don't think anybody would change all that, at that expense, just for the giggles of it.
#9
If you do not have the "hole shot trans" I would guess you have a 1:1 transmission. I would suggest our OJ 13 X 11.5 LC 1" Fully CNC machined 3-blade. This propeller will have better low end than your previous 4-blade and run a bit faster on the top end, 1-2 MPH. A new prop nut is never a bad idea. Give me a call if you have any other questions. Eric @ OJ PROPS - 800-359-9730 |
#10
I Can Vouch For The Prop Eric Is Talking About...my Pro Star Was Like A Corvette After Putting That Prop On. I Loved It!
Eric Is The Man! Thanks For You Help On My Boat Eric! Jay |
