  #121
Old 09-04-2013, 03:28 PM
bcd bcd is offline
Boat: 2014 X-2
For my front bags I used what they call the V drive bags - W701 which are 42"x16"x16". The X2 rear bags are 32"x18"x20". You could use the V drive bags back there, they just won't fill in completely.
Here's a picture of the V drive bags filled up front: http://www.mastercraft.com/teamtalk/...573#post945573
Old 09-04-2013, 03:30 PM
bcd bcd is offline
Boat: 2014 X-2
Here are some pictures of how installed the bags.
Old 09-05-2013, 03:53 AM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
Thank you verry much
Does that bag on starboard side, fill completly and does it kind of fit?
Old 09-05-2013, 10:33 PM
bcd bcd is offline
Boat: 2014 X-2
It's a little long, but I'd say it's at least 80% full, if not 90%.
Old 07-15-2016, 01:57 PM
Kell's Avatar
Kell Kell is offline
Boat: 2009 X2, MCX
I'm installing a piggy back bag in the port rear locker on an 09 X2, and I can't get the overflow fitting off the hard tank to install the 90 degree elbow fitting included in the Wagemakers kit. I tried a heat gun to "warm" up the existing fitting, then used channel locks, with no success. The existing fitting is plastic, and the channel locks kind of squeeze it to the point I can't get a good grip to turn. Don't want to bust it and have pieces fall into the hard tank. Any suggestions?
09 X2, MCX 350, VDig, PP, Heater, Shower, Bow Filler Cushin, Bimini, Wake Plate, 2 Tower Speakers w/Forward integrated docking lights, Tandom Low Profile Trailer
Old 07-15-2016, 04:28 PM
ccelia's Avatar
ccelia ccelia is offline
Boat: 2009 Mastercraft X-45
Did you already destroy the straight fitting that's currently in the tank?
If not, I would just reuse it. I had a hell of a time getting mine out when I plumbed in the overflow kit this spring. I ended up destroying the piece and had to bust it up into pieces to get it out. Luckily it was just a few larger pieces, so nothing went in the tank.
Old 07-15-2016, 04:53 PM
Kell's Avatar
Boat: 2009 X2, MCX
Thanks Ccelia, good to hear I'm not the only one that is experiencing this stubborn fitting. I didn't destroy that fitting, so I'll just hook up the bag fill line to that and see how it works.
Old 09-01-2016, 03:39 PM
Mpowerx15's Avatar
Mpowerx15 Mpowerx15 is offline
Boat: MASTERCRAFT X15
guys i have a 2007 x15 and wanted to do the same as Ronie , I'm getting ready to order the bags from WakeMakers but don't know wich one will fit my x15 , or is there a better option from wake makers , what kind of fitting will i also need ?
also this website has both fly high fat sacs and all hardware ,would this be all i need ? or should i order everything from surf makers?
http://www.waterskis.com/Custom-Mast...st_upgrade.htm
fly high, x2 ballast
