Old 07-22-2008, 01:29 AM
jbr383's Avatar
jbr383 jbr383 is offline
Boat: 2003 X2
Where is the transmisson vent / breather
I know this is an old issue and I've done a lot of searching but I haven't found exactly what I was looking for. I have a 03 X2 and I've been trying to get the water out out of the transmission. I know I need to check the cooler for leaks and keep water out of the bilge and possibly change the tranny seal. I've heard that when Mastercraft was having a lot of trouble with water in the trannys it was from pressure in the transmission case sucking water through the seal so they added a vent. This may have been a recall but I'm not sure. Could someone please tell me what the vent looks like or post a picture. Thanks.
Old 07-22-2008, 09:57 AM
Skipper
On Velvet Drive transmissions the vent is a 3/8" dia. steel, spring operated vent located topside just foreward and right of the neutral safety switch. It is just a small tube with a cap on it. To test just push it in and it should spring back out quickly. If it doesn't then it is bad. Sorry, no pic.
Old 07-22-2008, 11:01 AM
jbr383's Avatar
Boat: 2003 X2
So it sounds like the vent is spring loaded and it can go bad? If I have a vent it's defiantly not working because every time I unscrew the dip stick in the transmission there is a sucking noise.
Old 07-22-2008, 01:17 PM
Skipper
The vent can become clogged for various reasons. It is an inexpensive and easy repair. Just look on the top of the transmission for the vent.
Old 07-23-2008, 08:07 AM
Skipper
Looked at my Hurth transmission last night. The vent is located on the top next to the data plate. Seems like that is the place to look for yours.
Old 07-23-2008, 01:27 PM
denverd1's Avatar
denverd1 denverd1 is offline
Boat: 1986 Tristar 220, 351W, 2000 lbs
trans vent cap
there it be.
Old 07-30-2008, 03:16 PM
jbr383's Avatar
Boat: 2003 X2
Thanks for the picture. That is where I thought it was, but I couldn't tell how it worked as a vent. Like I said before when I pull the dipstick the tranny case is either sucking air in or letting it out. Either way the vent is not working. Looks like I need a new one. I'm guessing it's not a part my dealer will have on the shelf, I'll find out soon.
