Old 07-01-2008, 08:38 PM
gigem75 gigem75 is offline
Boat: 83 351
14x18 pulling 5K 52 on gps
My 83 PS19 w/powerslot swings a 14X18 and pulls 5k and 52 on the GPS. Does that sound about right for that setup?
title says the boat weights 2200lbs
Old 07-01-2008, 08:39 PM
justinglow's Avatar
justinglow justinglow is offline
Boat: 1995 Prostar 205
Are you talking 52 mph?
1995 Mastercraft Prostar 205
Former 1986 Mastercraft Skier
Old 07-01-2008, 08:45 PM
T Scott T Scott is offline
Boat: It's always changing! X-Star-Prostar190/205-Maristar
Sounds very fast for that setup to me. However, GPS units are rarely off by that much.
Old 07-01-2008, 08:47 PM
justinglow's Avatar
I was thinking the same thing. My 86 was a powerslot and I know it didn't go 52mph.
Old 07-01-2008, 10:27 PM
H20skeefreek's Avatar
H20skeefreek H20skeefreek is offline
Boat: '85 Stars and Stripes
I don't know how you could possible go that fast with that setup. Mine hit's 43/44.
ITCHIN' TO SKI, LET'S GO!!
Former Boat: 1985 MasterCraft Skier, Stars and Stripes
351W with PowerSlot and Perfect Pass
Click here if you need prayer, or wish to pray for those who do.
ski_king's Avatar
ski_king ski_king is offline
I don't think a stock engine will go 5200 rpm.
But if it did, 52 mph sounds about right.
I have had mine at 4600 rpm, 46 mph.
But that was with a tail wind, going downhill.
STARS AND STRIPES FOREVER
Old 07-02-2008, 12:00 AM
Boat: 83 351
The boat is new to me. The PO put ss allen head bolts on the valve covers and pulleys, not that is any indication of any internal mods but whoever put it together cared enough to add those touches so they obviously cared about what they were doing. The oil pressure is a couple of notches above 40 when hot and compression is good so it appears to be a fresh motor. The dreamometers read 44 when the gps read 52mph. It is a three blade prop which might explain the 18? It's not pulling 52 hundred, it tops out at 5000 and it is howling. I don't spend much time there.
Old 07-02-2008, 08:35 AM
ski_king's Avatar
Maybe you are on a river, going downstream with a 8 mph current?
Old 07-02-2008, 10:44 AM
WilliM1940's Avatar
WilliM1940 WilliM1940 is offline
It's possible if the thing has reworked or upgraded heads. A 1984 ski magazine review on the MC stated top speed 50 mph at 5000 rpm. Mine won't do it, and specs say 4400 rpm tops but consider that Rob Shirley probably had the standard engine massaged but stock looking for the test. Just a little work will put you there.
Old 07-02-2008, 10:54 AM
damaged442's Avatar
damaged442 damaged442 is offline
Boat: 1989 Tristar 190, Indmar 351, 250HP
I think it is possible with that size prop. A 14x18 will give a some more top end than the 13x13 that I'm running at 43-44. My bud has that same 14x18 prop on his Maristar 225VRS and he's got me by at least 5 mph. Your boat is significantly lighter. How it it out of the hole? I know there are some prop pros around here. They will probably know more than I.
1989 Tristar 190 - Indmar 351, 250HP, 1:1, 580 hours
